Check Engine Light On, With No Codes - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 11-09-2013, 08:23 PM Thread Starter
So I fired off the truck yesterday morning and the check engine light immediately came on. It was cooler than when I normally start it, probably in the 30's, but I let the grid heater warm things up prior to starting it. The truck ran fine and nothing seemed out of the ordinary other than the check engine light not going off. I've cycled the key several times to clear it like I had in the past, but its still on. Additionally, there's no error code. I just see a line go up and down in the odometer display, all the gauges move incrementally together, then when the cycle is done, there is no code and the check engine light stays on. Any ideas?
'99 QCLB, NV4500 Southbend Dual Disk, 5'' Turbo Back, BHAF, Edge Drag Comp, AD100, Fuel, Boost, Pyro gauges, 5.5'' Skyjacker Lift, 3rd Gen Wheels.
NorCal352 is offline
post #2 of 20 (permalink) Old 11-09-2013, 08:42 PM
Rescue Tower
Shainer's Avatar
Key trick is worthless, so don't rely on it. At any rate it was displaying it due to low voltage while the grid heaters were cycling right after a start.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
The Following User Says Thank You to Shainer For This Useful Post:
Mopar1973Man (11-09-2013)
post #3 of 20 (permalink) Old 11-09-2013, 09:00 PM Thread Starter
That makes a lot of sense, is there any way I can clear it without a tool or taking it to the dealer?
post #4 of 20 (permalink) Old 11-09-2013, 10:55 PM
Absolutely not. Must be cleared by a dealer or a code reader. Auoparts store may do this free of charge (sometimes) !! I'd buy a cheap scanner from harbor freight or any autoparts stores carry these.
.02 Cummins HO / 6spd / 4x4 / LBQC / Edge JWA / BD /200* T-Stat / Homemade HIGHIDLE /
cummins6sp5.9 is offline
The Following User Says Thank You to cummins6sp5.9 For This Useful Post:
post #5 of 20 (permalink) Old 11-10-2013, 09:45 PM
Rescue Tower
Shainer's Avatar
There is no error code... It's goal is to bring your attention to the instrument cluster. When you see that light you are supposed to scan all your gauges. That's when you would see the low voltage. Then you would see the voltage rise, and the warning go away.
You may want to check the health of your batteries though.
Shainer is offline
post #6 of 20 (permalink) Old 11-10-2013, 09:47 PM
You could always clear it by disconnecting the battery for 15 minutes.
Tom
Guaranteed Auto Parts
Call Toll Free: 1-800-790-0915
Tom at G Auto Parts is offline
post #7 of 20 (permalink) Old 11-10-2013, 09:48 PM
Rescue Tower
Shainer's Avatar
Epic fail.
Shainer is offline
The Following 2 Users Say Thank You to Shainer For This Useful Post:
cummins6sp5.9 (11-10-2013), Mopar1973Man (11-18-2013)
post #8 of 20 (permalink) Old 11-10-2013, 10:02 PM
Absolutely NOT. You MUST use a scanner !!!
Unhooking the batteries for a week Ora month will not do anything but make you reset your clock !!!
post #9 of 20 (permalink) Old 11-10-2013, 10:10 PM
Let me reword my post. Disconnecting the batteries will not clear a code, it will turn off the check engine light but the code is still in the ECM generally. Since he has no code, disconnecting the battery should turn the CEL light off
Tom
post #10 of 20 (permalink) Old 11-11-2013, 03:31 AM
98Dodge01's Avatar
If you can find someone with a smarty that is unloaded from their truck you can use it to read your code and clear it
98 QCLB, 6 spd swap, Valair Billet twin disk, II silver bullet 64, A1H11 xhd studs, fire rings, HRVP, Airdog 150, Quad adr and smarty, scheid lightning 2 150's
98Dodge01 is offline
post #11 of 20 (permalink) Old 11-11-2013, 10:14 AM
Rescue Tower
Shainer's Avatar
And then you have to recalibrate the APPS
Shainer is offline
post #12 of 20 (permalink) Old 11-18-2013, 02:29 PM Thread Starter
I bought a code reader and saw the truck had thrown the overboost code (p0236) and the grid heater code. It still throws both codes on a pretty regular basis. Any ideas on an easy fix?
