bleed all 6 injectors after fuel filter change? - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 07-08-2008, 10:09 PM Thread Starter
Is it recommended to bleed all 6 injectors after changing the fuel filter?
I failed to cycle the lift pump after changing the filter, the truck started and died within a few seconds.
Bled at vp pump banjo bolt, and bled the injectors I could access when i got it running. If I remember correctly I could reach only 1, 3, 4 5.
Is it possible for air to remain trapped in the injectors I did not bleed?
Thanks
Anton
asheng is offline
post #2 of 5 (permalink) Old 07-08-2008, 10:10 PM
I wanna go fast...
Chris Mallett's Avatar
It is not necessary to bleed all of them, if you are getting fuel to the ones you are cracking, it should start and clear out the others.
2005 QC LB Dually, sold.
2007 Mega Longbed Dually, twins, fuel, trans, 19.5's. Long and white. Not something I can normally say...
Chris Mallett is offline
post #3 of 5 (permalink) Old 07-08-2008, 10:15 PM
Rollin Smoke Diesel.com
Rollin Smoke Diesel's Avatar
iTrader Score: 20 reviews
Sometimes it may take awhile. Make sure the filter canister is filled with diesel. If cycling the pujmp doesnt help, start by bleeding at the filter housing to the VP44 and at least one (maybe two) injector lines.
You'll get it going :thumbsup
Contact us for all your diesel performance needs!
219-851-1195 Monday-Sat 8am-5:30pm CST, online ordering 24/7, Please Email
no PM's
Rollin Smoke Diesel is offline
post #4 of 5 (permalink) Old 07-09-2008, 04:20 PM
JSPulliam21's Avatar
Bleed the filter. You should be able to get it started with just that, but if not you will need to bleed 1, 3, and 4. Open them up good and have someone crank until you get the air out and it tries to start. Tighten the nuts after the air bleeds out, and crank until it starts. Do not crank longer than 30 seconds at a time. Once it starts let it run for a while to get all of the air bled out.
98.5 3500 QC LB NV4500 4x4 3.55 SRW, DiPricol gauges, BHAF, 4" Silverline, FBD 150's, Edge Comp, Valair 3800 DD, Draw Straw, 1/2" Filter to IP Line, FASS 95HPFP, 2" Leveling Kit, DSS, 35" Toyo M/T, KDP killed 403HP/899 TQ
JSPulliam21 is offline
post #5 of 5 (permalink) Old 07-09-2008, 06:23 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Here is the re-prime write I've got...
Reprime Fuel System
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For This Useful Post:
Double-O-C (04-27-2011)
