Code P0122 - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 08-05-2006, 08:35 PM Thread Starter
Mopar1973Man.Com
Mopar1973Man's Avatar
Code P0122
Ok guys...
I've got a P0122 code (APPS Voltage Low). What would you guys suggest I do before I start ripping out wiring and parts??? No problems yet but I better ask some other guru's on what to do...
Suggestions please...
2002 Dodge 2500 (276k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
1996 Dodge 1500 (163k miles) - 5.9L V8, Dynamic 46RE Tranmission, Mopar Performance PCM
Mopar1973Man is offline
post #2 of 11 (permalink) Old 08-05-2006, 11:21 PM
got...DIESEL?'s Avatar
The wifes did this two days ago....accompanied by a 1693. I reset the APPS and all is well.
turn on the key and with it left on, disconnect the batt negatives for about half an hour or so to fully discharge all the capacitors in the PCM. After the elapsed time, turn off the key, hook your batteries back up then turn on the key without moving the pedal. Now slowly depress the pedal all the way to the floor and then release it slowly all the way back up. The PCM re-learns the voltage curve and your code goes away...hopefully.
Chris
In NW Florida? Get a hold of me...it's time Dodge makes it statement in these parts!!
'95 2500 Std Cab 4X4...
DTT billet trans and billet triple disc, billet flexplate, compound turbos, AEM Dryflow, 160 pump, custom plate, 191's, EDM370's, peaked and tweaked AFC, rack control plug, 20*, 3K, head studs, marine +.020 HG, Water/meth
got...DIESEL? is offline
post #3 of 11 (permalink) Old 08-06-2006, 12:31 PM Thread Starter
Mopar1973Man.Com
Ok... Got Diesel I'll give that a try later on this weekend if I remember with everything I'm doing...
It just mean I got to reset the clocks (Temp gauge and radio) And reprogram the temp gauge too... Arrrrrgggghhhh!
Thanks for the idea...:thumbsup
post #4 of 11 (permalink) Old 08-09-2006, 12:01 PM Thread Starter
Mopar1973Man.Com
Update...
Ok..
It seems to me that the APPS reset did the trick. It also wiped all errors out of the PCU/ECU computers even than darn ol' P1693. The batteries were disconnected for over 24 hours.
I've driven only about 50 miles but still no codes yet... So I would say that the problem is fixed.
Good going Got Diesel!!! :thumbsup
post #5 of 11 (permalink) Old 08-09-2006, 04:23 PM
glad to hear it. The 1693 is still present in my wife's, I figured it was a hardcode that needed to be cleared with a scanner, as no other codes are present.
post #6 of 11 (permalink) Old 10-04-2010, 10:56 AM
SD95Turbo's Avatar
mine was acting up the other day. I'll be goin down the road and the tach will jump a couple hundred r's and drop back to normal it gets real annoying but I noticed its only when the pedal is in a certain "range" and thats around 30 to 40 mph so I took it in to a tranny shop fearing the worse he said my apps is probably to blame but didn't give me any remedy for it. well I checked the codes last night and I have the P0122 showing up. I am going to go and try your trick got......diesel and I'll let ya'll know if it worked out for me later today.
Josh
1998 Chevy K1500 lifted a lil-Current-
1998.5 QCLB, 5spd, 240k 2001 24v-Sold-
1995 CCLB, 5spd, 260k, -Sold-1995 CCLB, Auto, 350k-Sold-
SD95Turbo is offline
post #7 of 11 (permalink) Old 10-04-2010, 01:13 PM
Diesel Filled Veins!
Sandman76's Avatar
Josh
Dug yourself up a 4 year old thread here!
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
post #8 of 11 (permalink) Old 10-04-2010, 03:07 PM
SD95Turbo's Avatar
Haha I sure did...and thank god I did cured all my problems. No more annoying rpm spikes.
Josh
post #9 of 11 (permalink) Old 10-05-2010, 06:41 PM
Sandman76's Avatar
Josh
Although you got this issue corrected, it may be an indication of your APPS heading into retirement. A new APPS from Dodge will run you around $300-$400 so what I would suggest is either find an APPS in the Classifieds section on this forum or upgrade to the TIMBO APPS. I have the Timbo Apps and although I don't notice any difference in performance, I know it is constructed much better than the OEM one.
Timbo APPS Contact Information
I only changed mine because of high mileage and didn't want to be in the middle of nowhere with APPS issues. At the bottom of that link is Timbo's website where you can order directly from him or go to Genosgarage.com and search for APPS.
post #10 of 11 (permalink) Old 03-12-2013, 08:42 PM
i have a 2001 5 speed cummins, I have 3 codes showing, this worked to clear the 0122 and 1694 but a third code is still showing... 1693.. help anyone?
walker1288 is offline
post #11 of 11 (permalink) Old 03-12-2013, 09:02 PM
WillM's Avatar
iTrader Score: 10 reviews
P1693 codes (SOLO)
Ranch Truck: '98.5 QCDRW, NV4500, 2WD, BHAF, Straight Pipe, FASS, Gauges, Steering Box Stabilizer, Ranch Hands
My Truck: '91.5 RCLB, Getrag, 2WD, Leveled, BHAF, 4" Straight, Isspro Fuel Pressure/Boost/Pyro/Tach/Oil, HX35, 24V Intake Horn, PS I/C, 3" Intake Plumbing, THD Competition 6x.013", VE Tuned, Hot Screw, Piston Pump, KSB Spacer, THD Pin, 366 Spring, Valair, A1 Studs & 60# Springs 282HP/692TQ
WillM is offline
