Shifting late from 1st to second? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-14-2013, 03:44 PM Thread Starter
ColinD's Avatar
Lately it's been shifting late and today it wouldn't shift out of first. I shut of the truck and restarted it and it will be fine and shift normally only does it from 1st to second and I have no check engine codes and oil level is fine. Tranny isn't slipping. What do u guys think it could be?
01.5 quad cab cummins, 5in exhaust, s@b intake, bank high ram, raptor 100, 1/2 big line kit, fuel ,pyro,boost gauges. 3 piece header. 47re single disk torque convertor and valve body. 33" on rock stars. Edge comp hot unlock.
ColinD is offline
post #2 of 4 (permalink) Old 09-14-2013, 07:10 PM
VP Moderator
dozer12216's Avatar
Adjust front band. It's external adjustment.
dozer12216 is offline
post #3 of 4 (permalink) Old 09-14-2013, 08:25 PM Thread Starter
ColinD's Avatar
Thanks looks like it worked.
ColinD is offline
post #4 of 4 (permalink) Old 09-15-2013, 08:43 PM
late shifting
I have had similar issue only from third to fourth. it will rev up to 2500 and around 50-60 mph. is this a tranny slippage issue? fluid levels are fine.
1999 Ram 2500 4x4 3" lift stock down pipe to 6" stack motor stock and ready for upgrades
gaquackster is offline
