| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
BOMBS AWAY!
Fuel Pressure Gauge Line
Installing a Isspro FP guage. What type of line do I need to run from my tapped banjo to the gauge? Obviously I'm not the isolator setup. Also how do I go about bleeding this line?
01.5 Flame Red 3500 DRW 2WD LB QC Laramie 09 SRT8 Challenger *On Order* 47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel. Last edited by hipsi : 05-09-2008 at 08:47 AM. |
#2 (permalink) |
You can get steel braided line from summit. Im going to do this on mine. Because the Isolator SUCKS! my leaks very very slowly. Edit: Summit SUM-G2961 - Summit Gauge Accessories - summitracing.com
2002 Extended cab 24V 6 speed, ISSPRO gauges Fuel, EGT, and Boost. 5 inch pipe. Adrenaline chip! 31" BFGs FASS 95/150 2 Stroke oil (Super tech!) Injector pump at 88k(DiscountPowerParts1 Thanks!)
#3 (permalink) | |
BOMBS AWAY!
01.5 Flame Red 3500 DRW 2WD LB QC Laramie 09 SRT8 Challenger *On Order* 47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel. |
#4 (permalink) |
I have a 1/4" line on my 98 because it is what I had laying around. I have 1/8" line (like the little line commonly used on mechanical oil pressure gauges) on my 96. I put a restrictor orifice at the engine end on both trucks so If I did spring a leak it would be a slow one and it helps squelch the lift pump pulses on the 96. There is no need to bleed the line since the air pressure in the line is the same as the fuel pressure. The compressibility of the air in the line also helps protect the gauge from pulses in the fuel pressure.
96 3500 4WD, 47RE, gauges; 97 3500 4WD 47RE, gauges; 97 3500 2WD 5-spd; all club cab. 98.5 2500 2WD SB, 5-spd, gauges, quad cab |
#5 (permalink) |
BOMBS AWAY!
10-4... so just hook the line to my tapped banjo.. route to the gauge and away we go.. perfect. thanks!
#6 (permalink) |
BOMBS AWAY!
Also.. if i source a steel line locally, what fittings do I need, 1/8" NPT?
#7 (permalink) |
I used 1/8 Stainless Steel line with a needle valve.
1998.5 Dodge 2500 4x4 QC/SB 24V Cummins Diesel. 5 Spd Stick. 3rd gear synchro out. Dipricol FP, Quad ADR/Pulse, VP not tapped, AirDog FP150, 185,000 Miles. 3rd Gen TB, Lightforce 170s http://s148.photobucket.com/albums/s18/Duramax411/ |
#8 (permalink) |
I have a banjo bolt tap if you want it. It came with qaud chip. Im tired of it sitting on my desk. So if you want it Send me 2-3 bucks an Ill mail it your way lol
#9 (permalink) |
2 Cycle Oil Guru
![]() I used a oil pressure kit... The nylon tubing is rated for 100+ PSI I doubt a 15 PSI pump is going to blow it out... ![]() The oil pressure kit can be found at autozone for $8 bucks... Just use hot water to soften the tubing and it will route without a hitch... Then with the needle valve if it does leak just shut it down and no worries... As for bleeding its not required... Mine been in for over 4 years now and not a problem.
Michael Nelson - 2002 Dodge Cummins ![]() |
#10 (permalink) | |
BOMBS AWAY!
#11 (permalink) | |
2 Cycle Oil Guru
