241HD noise when accelerating - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 08-11-2013, 06:21 PM Thread Starter
When under 'load', in say 3rd, or 4th, the T/C 'grinds'. I've been told it's the 'chain', 'gear walk', no one seems to know for sure. So anyone here know what is causing this? T/C 'works' fine, just grinds when putting 'power' to it, NOT all the time. Thanks.
AirborneSF is offline
post #2 of 6 (permalink) Old 08-11-2013, 06:48 PM
KATOOM's Avatar
What year truck? Fill out your sig.
KATOOM is offline
post #3 of 6 (permalink) Old 08-11-2013, 10:58 PM
VP Moderator
dozer12216's Avatar
Are you trying to describe TC chain strech. Very common on 4WD left in 4WHD on solid surfaces.
dozer12216 is offline
post #4 of 6 (permalink) Old 08-23-2013, 03:22 PM Thread Starter
It's a 2000 diesel drw, 5sp, 4wd. I am (I believe), the 3rd owner, so no clue as to how it has been driven. So, the chain is the best place to look. Thanks.
post #5 of 6 (permalink) Old 08-23-2013, 04:28 PM
VP Moderator
dozer12216's Avatar
Put in 4WD on a dirt parking lot. Accelerate and you will get a ratching shake that may scare your drawers off if the chain.
Do not run our trucks in 4WD on good traction surfaces.
post #6 of 6 (permalink) Old 09-06-2013, 12:57 PM
Guest
Guest
Posts: n/a
I recently had a similar noise after I rebuilt my transfer case a 241dhd. The chain streached out so bad and wore a hole in the bottom of the case so I rebuilt the case combining two transfer cases to make one good one. Well anyway upon rebuild I forgot one of the c-clips in the tailshaft housing and it would get a grinding noise under heavy load or during a shift. Needless to say I pulled it apart and the mainshaft was moving back and forth from the missing c-clip. The edges of the chain started to get chewed up quick. Luckily I didnt drive it that much like that.
