99 Dodge runs great one minute then smokes and jerks the next - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 06-26-2013, 03:32 PM Thread Starter
harry o's Avatar
1999 Dodge 5 speed runs good one minute then bad the next ... Codes were p1693 and po602 ... what is the po602 thanks ...
1999 Dodge 3500 ... 2WD ... 24 V ... 5 Speed ... Backhoe pulling truck ... isspro fuel gauge # R5604 from city diesel Decatur Alabama 256-350-5160 Call them they'll fix you up with fuel pressure gauge braded line and snubber ...
harry o is offline
post #2 of 6 (permalink) Old 06-26-2013, 04:02 PM
I did have erratic idle after replacing injectors and did not disconnect the battery.
A couple of days ago I pulled the valve cover and checked torque on injectors.
They were all out of spec for torque. I checked lines and were fine. My idle issues went away.
I got p602 and reader said it was something with the idle. I replaced apps a month ago so i disconnected battery, did apps reset and code did not came back so I am figuring because of the erratic idle, it threw this code.
(When I replaced injectors,I tightened the hold downs to spec, then torqued lines to spec and put it all back together, guess I should have checked the hold downs again after torquing the lines in head! )
1998.5 2500 4X4 Quad Cab,5.9 Cummins, (Block 53) VP44, 47RE, RV275's,4 inch Magnaflow Exhaust,K&N intake with Amsoil dry air filter, Raptor 100,Pac Brake,Firestone Ride Rite,Big D Off Road Steering Brace,Isopro egt, fp and boost gauges Timbo APPS, Diablo Powerpuck
crackshot is offline
post #3 of 6 (permalink) Old 06-26-2013, 06:53 PM Thread Starter
harry o's Avatar
Well I was about to get ready to run my Dodge that I just bought off in the river and say to hell with it !!!! I knew it was getting way to much fuel and Ive saw this black box under the hood that looked like it was some kind of add on ... It had EDGE written on it so I looked it up ... Found out it was for more power ... Took that junk off and now my truck runs like a new one ...
harry o is offline
post #4 of 6 (permalink) Old 06-26-2013, 06:58 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
Mopar1973Man's Dodge Cummins Articles - P0602 ECM Fueling Calibration
Sounds like you had an edge ez, they not only add power but will help with mpg also.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is offline
post #5 of 6 (permalink) Old 06-27-2013, 12:34 PM
blackknight24v's Avatar
Harry in response to your reply in the other thread your ecm is mounted on the driver's side of the block the pcm is on the firewall. Before you go throwing parts at it clean the grounds,and batteries, reset the codes and give it a try.
24V money pit, New Paint & fancy new noise makers in cab.
FASS 150, BHAF Cold air, 5" exhaust,CFM+ intake horn, DAP 160's, Quad ADR, SDX 62/71/13, Revmax Signature with triple disk converter, Hamilton 110's,MaxSpool pushrods
blackknight24v is offline
post #6 of 6 (permalink) Old 07-04-2013, 06:56 PM Thread Starter
harry o's Avatar
ok I did what you said ... THE PROBLEM COMES BACK IN A DAY OR SO ... Where do I get a ECM ??? OR can I flash my ECM AND FIX IT THAT WAY ... I CAN GET A ECM FROM DODGE FOR $900.00 Damn cant I find one at a better price some where ...
harry o is offline
