Common rail 5.9 block same as 2nd gen - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 05-07-2013, 07:47 PM Thread Starter
HOYBOY's Avatar
I have a 53 block in my 99 since its going to be my pull in truck want to get better block for it itls the common rail block going to be the same block as a 2nd gen block?
HOYBOY is offline
post #2 of 10 (permalink) Old 05-07-2013, 07:54 PM
Substation Operator
speed185187's Avatar
iTrader Score: 5 reviews
Block's are the same, heads are different.
16 Chevy 3500 CCLB Dually LML
14 K1600GTL-E
03 Jetta GL TDI platinum grey (summer driver)
03 Jetta GL TDI reflex silver (project car)
13 C-Max Energi (hers)
speed185187 is offline
post #3 of 10 (permalink) Old 05-07-2013, 08:10 PM
Master of Mayhem NASFIG
rpage's Avatar
the coolant ports are different and maybe some of the oil ones.
rpage is offline
The Following User Says Thank You to rpage For This Useful Post:
Marq92 (05-07-2013)
post #4 of 10 (permalink) Old 05-08-2013, 01:57 AM Thread Starter
HOYBOY's Avatar
Would I be better off buying a 2nd gen non 53 block?
HOYBOY is offline
post #5 of 10 (permalink) Old 05-08-2013, 02:04 AM
rpage's Avatar
i would say it would be easier and cheaper to go that route.
rpage is offline
post #6 of 10 (permalink) Old 05-08-2013, 07:50 AM
also remember some have a crank sensor (tone wheel on the crank) and a cam sensor, some engines only have a cam sensor
something else to research
I believe my 01 only had the cam sensor
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #7 of 10 (permalink) Old 05-08-2013, 08:12 AM
rpage's Avatar
01-02 are the only ones, but the hole is there for it and if he uses his crank its a mute point.
rpage is offline
post #8 of 10 (permalink) Old 05-08-2013, 08:18 AM
iTrader Score: 17 reviews
the blocks are most certainly not the same... 12v/VP? similar (same in late 97/98 STORM blocks) but the CR block is completely different and is nowhere near an interchange
drunk on diesel is offline
post #9 of 10 (permalink) Old 05-08-2013, 01:07 PM Thread Starter
HOYBOY's Avatar
I heard somewhere that the 12v blocks are the same this true or no?
HOYBOY is offline
post #10 of 10 (permalink) Old 05-08-2013, 01:14 PM
ROLLIN SMOKE DIESEL
Broke Down's Avatar
iTrader Score: 13 reviews
Hoyboy, read this thread.
3rd gen head on 2nd gen block 24V
A 24 valve blocks and heads will bolt up with small modifications but pistons are different between the two. Also from '94-'02 the motor mounts are the same, the early 1st gen blocks have different mounts as well as the 2003 - current models do. If the body style changes so do the mounts. You can put a 12 valve head on a 6.7 block with the correct modifications.
Duke- 2004.5 2WD SSR Tuned
Feel free to email me for quotes:
Monday-Friday 8am-5pm CST, online ordering 24/7
Broke Down is offline
