Valvoline or shell? - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 01-14-2013, 02:27 PM Thread Starter
Dborbone's Avatar
Valvoline or shell?
Valvoline premium blue 15w-40 or shell rotella t 15w-40?? I have always used Rotella t but today at my local tractor supply the valvoline is only 12 bucks a gallon. Are there any problems switching back and forth? My guess is same crap. The valvoline is recommended for cummins though. Any opinions on what's better? Or are they the same
Sent from my iPhone using AutoGuide.com Free App
02' 2500 QCLB, AUTO, 4x4, 2.5" leveling kit, 8" black single stack, pro rack, BHAF, Banks high ram, silencer ring MIA, waste gate sealed, DS power puck
Dborbone is offline
post #2 of 23 (permalink) Old 01-14-2013, 02:40 PM
Rlkend's Avatar
Valvoline isn't bad
Rlkend is offline
post #3 of 23 (permalink) Old 01-14-2013, 02:54 PM
VP Moderator
dozer12216's Avatar
Botlh oils mentioned along with a passel of other quality oils will do the job just fine. In fact, you will never be able to tell the difference internally as long as the owner does his jobs. Yes, you can change brands without prejudice, although I suggest staying with the same oil on a particular oil change.
dozer12216 is offline
post #4 of 23 (permalink) Old 01-14-2013, 03:55 PM
PA VICE PRESIDENT
Ramitt's Avatar
12.68 for rotella at my local walmart
Mitt
2002 2500 SLT 4x4 6 Speed 3.55's. SB Dual Disk ,Fass 150,Edge Juice w/attitude, 150hp injectors, AFE intake,5in str8 piped exhaust,20% window tint,Leveled with 33's,Halo head lights w/55watt hid's, 35watt hid fog lights,Ram Air Hood,High idle mod.
Dynoed at 420 hp - 960 ft-lb
Ramitt is offline
post #5 of 23 (permalink) Old 01-14-2013, 05:39 PM Thread Starter
Dborbone's Avatar
Soooo...same spit. What's everyone reccomend? Stick with Rotella for a few extra bucks
Dborbone is offline
post #6 of 23 (permalink) Old 01-14-2013, 06:02 PM
D-Roc's Avatar
aww jeez...not this crap again...
1998 QCSB 5 sp, 3.55, EGT, boost, SB intake, 4 exhaust, KDP, AFC mods, 8 plate, FASS T D10 125G , TT OFV50, SBC OFE
D-Roc is offline
The Following User Says Thank You to D-Roc For This Useful Post:
Dborbone (01-15-2013)
post #7 of 23 (permalink) Old 01-14-2013, 06:38 PM
SuperISBee's Avatar
Nothing wrong with Valvoline Premium Blue. That's actually the oil recommended by Cummins.
All engine manufactures (OEM speaking) recommend a particular brand. I'm sure there are perks to the manufacture for stating xxx brand oil.
So, if Cummins recommended Shell Rotella, that would be fine as well. The only difference would be the perks to Cummins would come from Shell vs. Valvoline.
It's all about marketing.
Just ask any of the big oil analysis companies how much difference there is between oils. There all basically the same, more so these days with all of the EPA crap.
Unless you have "built" your engine i.e.; aftermarket valvesprings, camshaft etc. you really don't need to get real picky. With the above I think it's a good idea to add some supplimental zinc in the correct qty.
Additional additives to oil is really the only difference between brands, base stock is the same.
"Better to remain silent and be thought a fool than to speak out and remove all doubt"
SuperISBee is offline
post #8 of 23 (permalink) Old 01-14-2013, 07:08 PM
PA VICE PRESIDENT
Ramitt's Avatar
Run either they are both good oils! I run rotella and so do most of the rig guys.
Mitt
Ramitt is offline
post #9 of 23 (permalink) Old 01-14-2013, 07:14 PM
tail heavy's Avatar
For my 96 Cummins I have used Valvoline and have
gotten over 379,000.
So it must be good.
I use the rotella for my 09 cuz its cheap at Walmart.I only have 65,000 on this one.
No problems so far.
tail heavy is offline
post #10 of 23 (permalink) Old 01-15-2013, 12:19 AM
hockgeiger87's Avatar
Haha the ole oil thing again. I called cummins and the recommend valvoline for all their engines and that is what they put in them when they get to fill. that was 4 months ago. I have used it since I bought my truck. Shell smells weird for a few hundred miles to me
98.5 Dodge 2500 SLT 24V 4X4.BHAF, Air Dog 150, CFM Intake, Juice and Attitude, R1 Industrial Injectors, SD Exhaust Mani, Glacier Grid & Plenum. Built Trans: mainly Goerend. Still throwing money at it. BIG DREAMS!!
hockgeiger87 is offline
post #11 of 23 (permalink) Old 01-15-2013, 12:31 AM
Shell Delvac 1300 $12 bucks/gal at Wally world.
.02 Cummins HO / 6spd / 4x4 / LBQC / Edge JWA / BD /200* T-Stat / Homemade HIGHIDLE /
cummins6sp5.9 is offline
post #12 of 23 (permalink) Old 01-15-2013, 01:38 AM Thread Starter
Dborbone's Avatar
Well thanks fellas that's what I was looking for. Just some opinions on what people like better. I kinda knew it was the same old stuff. I was a little curious if it stank like rosmella t lol. I guess the longevity should be the same too. I think I'll give the valvoline a shot this time and see how it is. And then ill go from there.
Dborbone is offline
