My 99 5.9 block heater...wtf - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 12-25-2012, 04:15 PM Thread Starter
RJ621's Avatar
Ok so i find my plug has never actually been plugged into the side of my block...i pushed...i shoved...i tried different angles...even used vasoline to try and lube its way in....now...i do some research online, none of the plugs look like mine that people offer....the ones online are all red with a 90 degree angle...mine is just black and straight...and it wont go in...so i thought about replacing the block heater port itself....none of those look like the one on my truck either!!!!! ok sooo....can someone with a 99 or 2000 or whatever is going to be the same as mine please post pics of your heater plug and plugin port on the engine....i guess im going to have to buy a new one of each to make this work...its effin cold outside
99'
NV4500 QCLB
Southbend Clutch
Pureflow Airdog
Industrial Injection
Quadzilla Performance
RJ621 is offline
post #2 of 13 (permalink) Old 12-25-2012, 09:13 PM
You don't have to buy one of each Just get a new replacement from Napa, CARQUEST or your favorite auto parts store. There no that hard to replace. How cold is effing cold? It was 8* here in western NE this morning at 6:30. Mine fired right up after the WTS light ended. Kicked my high idle on (ice scraper). Came out ten minutes later Andrew the temp gauge was reading 170*.
.02 Cummins HO / 6spd / 4x4 / LBQC / Edge JWA / BD /200* T-Stat / Homemade HIGHIDLE /
cummins6sp5.9 is offline
post #3 of 13 (permalink) Old 12-25-2012, 11:56 PM
cummin's crewcab builder
iTrader Score: 11 reviews
Geno's Garage.com really cheap plus they even have a bumper hook/up
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto ,hx35 with a 14 non wg housing ,366 spring and fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #4 of 13 (permalink) Old 12-26-2012, 02:19 AM
CumminsCowboyNE's Avatar
When dodge sells a new truck with a cummins they come installed with a block heater in the block but no cord. You have to buy the cord at the dealership. Maybe just go get a new cord maybe your heater is still good?
Get off my lawn.
CumminsCowboyNE is offline
post #5 of 13 (permalink) Old 12-26-2012, 09:25 AM Thread Starter
RJ621's Avatar
yeah its just odd as to how its shaped...it looks like neither style that cummins had as an option....ill figure out something
99'
NV4500 QCLB
Southbend Clutch
Pureflow Airdog
RJ621 is offline
post #6 of 13 (permalink) Old 12-26-2012, 11:30 AM
2002's Avatar
Somebody replaced the heater with an aftermarket type.
2002 Ram 2500 QCLB 4X4, R47E, 3.55, 4"exhaust, Isspro EV2 Gauges, Fuel, EGT, Trans. Hypertech Programmer
2002 is offline
post #7 of 13 (permalink) Old 12-26-2012, 01:01 PM Thread Starter
RJ621's Avatar
yeah it probably is, the plug hanging from my bumper wont even go into the slot, so the plug and the hole for it are either different or wore out...idk...ill figure it out
99'
NV4500 QCLB
Southbend Clutch
Pureflow Airdog
RJ621 is offline
post #8 of 13 (permalink) Old 12-26-2012, 04:43 PM
post a pic of it, someone will id it for you
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #9 of 13 (permalink) Old 12-26-2012, 04:47 PM
all I can say is if your going to get a new one DON'T GO CHEAP. Get the good one and enjoy years of service. get a cheap one and plan on replacing it one a year or more. Absolutely do not plug it in without any coolant in the block.
Get off my lawn.
post #10 of 13 (permalink) Old 12-27-2012, 03:41 PM
Do these heaters make a noise when plugged in? Mine makes no sound at all and I am pretty sure its broke because the truck had no heat four hours later.
2006 RCLB 4x4 LARAMIE!!
ummins: Willy's whistler intake, GDP fuel filter kit, Edge Insight CTS
ryguy3321 is offline
post #11 of 13 (permalink) Old 12-27-2012, 06:46 PM
slayerfish's Avatar
Mine always makes an arcing sound when I plug it in.
'16 2500 Bighorn 6.7 Cummins CCLB 4x4 68rfe
slayerfish is online now
post #12 of 13 (permalink) Old 12-27-2012, 07:36 PM
rflrowdy69's Avatar
My old neighbor in montana had a P.O.S 6.2 detroit diesel in a chevy. he was too cheap to buy a block heater so i would put a hair dryer under the hood and let it run all night. burnt the motor up in the hair dryer about every other week but hey, it worked
2500 5spd, Southbend DD, Edge comp, Raptor 150,4" straight pipe, BHAF, Phatshaft 62, ARP studs , Weston Shupe 7x.009's
Overkill is underrated
rflrowdy69 is offline
