98.5-02 PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING .
I just bought my 01,6sd last week and it ran fine before the mods. Modifications included losing the muffler and straight piping it, a BHAF and removing the silencer ring but now it seems to hesitate right before the turbo kicks inike it wants go but something's holding it back. Once it hits the sweet spot it just starts hualing beepbeepbeep. Any idea what could have happened, need more fuel? If so how can I fix it? I don't want to start going crazy with mods just a really efficient running motor. Thanks
2001 SLT,4x4, 6spd,HO---------1969 Scout 4BT,Turbo400,Atlas 4.3,D60,14Blt,39.5" Super Swampers
does it do this at low boost any RPM? or is there a certian RPM where the power is not there?
my first thought would be the MAP sensor, the other would be the CPS, if the 01's have one.
04.5 6spd QC 4x4 4.10's line-x on the rockers, TST, smarty 5-31-09, 475/853
73K still on the stock clutch, lift pump and all other internals
giving her 'H' 'E' double hockey sticks every day
I'm not realy up on the inner workings and how the VP44 pump runs if it is a mechanical throttle, or like my 3rd gen electronic.
since it happens at a certian RPM range you might need to look at your TPS(throttle possition sensor) if it is electronic. but then at also any RPM you have hesitation that would lean more twards the MAP(Mass Air Pressure) sensor not being able to read low boost properly and I know the 2nd gen 24v's have them.
I did the APPS reset you recommended and the truck runs great now; really smooth with no hesitation. I test drove late morning when temps were about 60's I hope it doesn't act up when temps hit 90's later today. I'm:thumbsup in Los Angeles,Ca. Thanks for the great info. This website Rocks!!!:thumbsup
I dont mean to invade this post, but my truck hesitates also, does my truck have the APPS reset? Forgive me (newbie) what is an APPS? Also I tried the quick link for the reset, but it didnt come up for me, some kind of domain web page notice or something. PM me please
96' Ram 2500 Laramie SLT, Ext Cab, LongBed, 3/4 ton, 2wd ,w/ the 5.9L Turbo Diesel, 47RE AutoTrans., BHAF, #6 fuel plate w/ boost elbow, custom made air filter Heat shield, 4" turbo back straight piped.
No sir, you have a mechanical truck which is controlled by a throttle cable instead of the "drive by wire" setup on a 24V.
Your hesitation could be caused by any number of things. Have you changed the fuel filter? Have you cleaed out the fuel filter prefilter?
Keep in mind 96's dont have a whole lot of get up and go in stock form.
