98.5-02 PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING .
the timing is controlled by the IP, and pop pressure. if you developed an engine knock its usually one of those two issues.
i would pop and flow test your injectors first then go from there.
raising the viscosity of the oil, you can't 15w-40 is the normal, unless you want to go for regular 30w, but then you will loose the operating temp viscosity.
i would run the truck and use a stescope to find where this knock is coming from, and then go from there.
be forewarned that these engines are nortious for having their 1st cylinder to be off a bit just enough to cause it when its cold on my trucks anyways.
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 60hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 06 Dakota V6 Big Thanks to (FTE Diesel),(DAP),(DTT) They ROCK!
Its not from worn oil since it might have 100 miles on the new oil. But it's a bad rod bearing. Just trying to quite it down to trade it off.
There's a couple of ways to quiet a worn engine but I'm not going to divulge how.I got burnt before buying what appeared to be a good second hand car and at the normal value for it at the time only to discover a hundred or so miles later the crankshaft was toast.As far as I'm concerned, man up and tell any prospective buyer about the engine issue.
Tits and pistons burn money!!!
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator, half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open)125hp DAP injectors pushing on the pistons, BHAF and more to come
The Following 6 Users Say Thank You to irish power mad For This Useful Post:
That's fine if you don't want to... But thanks for ur input
I'm beginning to question if it is a rod bearing. Because i just went out to see if it would start after a week of sitting and the knock didn't come on till 20-30 seconds. Maybe it could be oil pressure related? But my oil pressure is about 40psi.
I found my 01 HO has a knock/tick when its cold. You can hear it well when you 1st fire it up. Does about 2-3 notable ones then calms down a bit. I noticed untill you get up to 190F in between shifts you will hear it tap/knock when the revs drop to about 1200 rpm. Thats the most noticeable rpm. Does not get worse with rpm. When i crack the #1 injector it quiets down and when you first sinch the injector tight it wil tap fairly loud a couple times when you retighten. THen quites down to a dull tick/tock. Hard to describe but its not a heavy knock. Kind of sounds like a worn lift pump lobe on a 12v.
The previous ovwner had it checked out at dodge and they said it wasin the programming ?
When you say 1st is off do you mean the IP timing ? is this a computer thing or pump releated ?
My truck had a new vp,injecotrs,lift pump. He said the noise was there before he changed any of the fuel system.
01 2500 QCSB 4x4 6 speed stock,99 QCLB 4x4 auto
91 mustang LX Coupe HCI
70 charger R/T(in restoration)
it is most likely i think just the design, when fully warmed up and the serpentine belt missing you can use a laser gun to shoot the exhaust manifold and see which one runs cooler then the others and that is the one, it is 9/10 either cylinder 1 or 5.
My truck its cylinder 5, it runs about 50- cooler then the others usually.
From what i have gathered it is completely normal, and for all we know it could be there to cause some load on the motor to allow it to warm up when its cold out.
The Following User Says Thank You to pepsi71ocean For This Useful Post:
Check out your flexplate. Mine has a nice knock in the bottom of the motor. After further inspection it comes out of the bellhousing. You'll find some aluminum shavings in there and with the inspection cover off it will get louder. I also had an oil analysis done and they said no way it was bad bearings. I haven't had time to change it out yet but ill post pics of it when I do.
__________________ MY TRUCKS 98.5 QC LB 4x4 auto edge juice, 4" exhaust, FASS 150 soon to have revmax convrverter and valve body
97 EXC LB 4x4 nV4500, 10 plate, he351cw SOLD! BROS TRUCKS 2011 CC LB 6.7 4x4 G56 3.73 gears stock for now!
04 CC SB 4x4 auto banks tecni cooler pack SOLD
95 EXC SB 12v 5x.011 4x4 auto revmax converter TFOD shift kit SOLD DADS TRUCK 2000 F350 CC Dually 4x4 auto 7.3PSD
Thanks for the info
