Grounding Problem - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 10-08-2012, 04:00 PM Thread Starter
krrz350's Avatar
Grounding Problem
The problem I have is about every three months I need to re-clean the grounds due to the eratic overdrive shifting problem. My truck has the sweet life, hardly any pulling or racing, just driven daily. I thoroughy clean each ground (not that they are dirty to begin with) and put a protectant on them when I'm done, but sure as the sun rise, about every three months the trans. will shift in/out of overdrive. Alt. is good (tried the fuse trick), and apps is newer (was not replaced because of o/d problem).I am kinda lost.
01 350k 2wd quad cab dually auto. 5" Straight pipe-power puck-Raptor 100-Issopro fuel,boost,egt-Fluidamper-hx35-bhaf-heavy right foot
96 Suburban SLT 2wd 6.5 turbo diesel
krrz350 is offline
post #2 of 9 (permalink) Old 10-08-2012, 04:01 PM
ghostman's Avatar
iTrader Score: 6 reviews
Batterys leaking acid?
Sent from my LG-P930 using Tapatalk 2
Dads: 2002 QCLB 2500|NV4500 4X4|BD Super B|gauges|banjo upgrade|assassin FP|Quad/V2|S&B CAI|4" TBE|CFM+|heater delete|Flex-a-Lite fans|SB OFEK|Weston's 6 x 0.011" micro-blind SAC|Tunnel Ram|steering box brace|98/99HD Steering
2002 QCSB|rebuilt dash and HVAC|Weston 7 x 0.011"|BD Super B|Edge EZ|4" TBE|billet tappet cover|S&B CAI
Mine: 2002 QCSB 2500|47RH/NV273 hybrid|12V|5x0.016" 155* Westons injectors
ghostman is offline
post #3 of 9 (permalink) Old 10-08-2012, 04:11 PM Thread Starter
krrz350's Avatar
No, terminals are as clean as the rest but I still clean them anyways. All the electrical wires are in very good shape as well.
krrz350 is offline
post #4 of 9 (permalink) Old 10-08-2012, 04:15 PM
Smile
why not just add another new 0[ought] or 1 heavy ground cable from the transmission to frame. keep in mind that the aluminum that bolt goes thru the trans can corroed.just make a good connection. that should last for a couple of years. jim e.
02 dodge 24 v 5.9 ISB QCab Lb a/c 3500 dually 6sp [nv5600] ,3.55 LSD-2wd -237,000 miles stock isspro fp-egt-boost BHAF-raptor 100[relocated to frame] BIG line kit- tank all the way to inj pu-EDGE comp silencer ring mia. 5 in exhst Valair HD single organic clutch
ex04 is offline
post #5 of 9 (permalink) Old 10-09-2012, 07:51 AM
There is no spoon
Haggar's Avatar
Krrz,
Ex has a point. You can add multiple grounds connecting everything. Use the compound from an electrical supply company that is made for lugging aluminum wire. This slows the corrosion associated with connecting to aluminum.
I would also use a copper compound on the steel to steel contacts.
You might have a GOOD automotive electrical shop check your truck for over charging and/or AC bleeding through the DC charging system.
It is very weird that you are having to clean so frequently. You may want to think about what you are cleaning with (could it clean, but then leave a residue that creates another round of oxidation on the terminals?) or the chemicals that you have in the air or drive through.
HTH
Hag
2001 QCLB (01.5) 4x4 NV4500, 3.55, 299k, FRRP, 98/99 HD, DOR HD Track bar, borgeson, VDO and Autometer Boost,pyro,FP Manual CAD. 285/75 on ARE Nitros
2001 QCSB 4x2 slushbox. 122k Stock (boost ga only atm)
99 K1500 300,000 SUBURBASAURUS FEDERALLY MANDATED ETHANOL ENRICHED.... 2 96 IMPALA SS(HIS AND HERS)
94 K1500 210,000 SUBURBASAURUS
2-97's K1500 & K2500 6.5 VIN F SUBURBASAURUS Jamie's & Kris'
Haggar is offline
post #6 of 9 (permalink) Old 10-09-2012, 08:44 AM
VP Moderator
dozer12216's Avatar
Gray connectors near right side battery.
Reposition alt. wiring and make ground fron alt housing to right side battery.
May have corrosion inside a cable. Look for swelling and green canker.
dozer12216 is offline
post #7 of 9 (permalink) Old 10-09-2012, 10:48 AM Thread Starter
krrz350's Avatar
Thanks to all so far. I am going to try the cable from the trans. to the frame. What I've been doing is cleaning the contact point on the body, frame, ect. and the terminal itself with a wire wheel on my angle grinder and then shooting a coat of batt. protectant on it after I bolt it back on. As far as the connectors by the bat. I have ohmed them out and cleaned the connectors with a filed down file and put a little conducting grease in them.
So... I'll let you all know in about three months,lol.
krrz350 is offline
post #8 of 9 (permalink) Old 10-09-2012, 11:12 AM
There is no spoon
Haggar's Avatar
Krrz,
Sounds like your are doing a pretty good job with it... especially using cond grease etc. Could the pins be yawning too much? (a name we gave to the female half that no longer springs back closed, as the elastic limit had been passed in the connector itself.) You might be able to bend the females just a bit to have a stronger mechanical hold. You also may want to think of getting replacements... you are having to play with them so often, it may cause a mechanical failure of the female before too long...
What a PITA!!!!
Haggar is offline
post #9 of 9 (permalink) Old 10-09-2012, 11:30 AM Thread Starter
krrz350's Avatar
So what your telling me is that a female is giving me a problem? Sounds about right
krrz350 is offline
The Following User Says Thank You to krrz350 For This Useful Post:
Haggar (10-09-2012)
