Crankcase vent filter? - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 09-21-2012, 10:46 PM Thread Starter
hi guys would it be okay to put a little breather air filter on my crankcase vent ? Just wondering if it would harm my truck or not. Any feedback is appreciated.
2001 dodge cummins automatic, 4 inch turbo back MBRP straight pipe, Quadzilla adrenaline, 100hp cpp injectors, hx40, Raptor 150 lift pump with big lines, TC manual lockup, amsoil 4510 air filter, banks intake manifold, custom made heat shield, fresh paint job.
Superrc84 is offline
post #2 of 11 (permalink) Old 09-21-2012, 10:57 PM
Clunk's Avatar
I wonder if it would interfere with the stock crankcase ventilation.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #3 of 11 (permalink) Old 09-21-2012, 11:03 PM Thread Starter
i was thinking of taking of the crankcase tube off and just putting a little breather air filter on it.
post #4 of 11 (permalink) Old 09-21-2012, 11:17 PM
Clunk's Avatar
If you close the crankcase vent, all blowby will exit your new breather, up high on the engine for easy access to the operators cab...
Clunk is offline
post #5 of 11 (permalink) Old 09-21-2012, 11:20 PM
Rescue Tower
Shainer's Avatar
What is your intended purpose for this? It won't stop oil from coming out, and could become a restriction causing other expensive issues.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #6 of 11 (permalink) Old 09-22-2012, 09:11 AM Thread Starter
no i dont lose any oil there is just a steam that comes out of it and i want to stop it
post #7 of 11 (permalink) Old 09-22-2012, 12:54 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
You don't want to stop the steam from exiting...
That's why I routed over the back of the engine so it doesn't get sucked in my the vents or the windows. Also no you don't want a filter on it because when it get wet with water vapor or oil it will eveentual plug up and blow the seals or gaskets on the engine.
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
post #8 of 11 (permalink) Old 09-22-2012, 02:15 PM Thread Starter
alright not planning on doing that lol thanks for the info
post #9 of 11 (permalink) Old 09-22-2012, 02:31 PM
MHPDBrewster's Avatar
Look at mopar mans write up, very good details and easy to do. I can't remember if it's on here or his website
Sent from somewhere in the oil fields on my Autoguide iPhone app
2006 Mega Cab 4x4 Auto: 3" BDS Lift, 2nd Gen Exhaust Manifold, AFE Intake, Pusher Intake Elbow, Silencer ring MIA, 4" MBRP TB exhaust, Mag-Hytec Tranny Pan, Recon smoked cab lights
Diesel is a lubricant, Gas is a solvent, you do the logic!
MHPDBrewster is offline
post #10 of 11 (permalink) Old 09-22-2012, 02:35 PM
Mopar1973Man.Com
Here you go...
Mopar1973Man's Dodge Cummins Articles - Crankcase Vent Modification
post #11 of 11 (permalink) Old 09-22-2012, 03:17 PM
musclecarman's Avatar
Here is a link for a crankcase breather. A little to pricey for me.
88-02 Dodge 5.9L Cummins Crank Case Breather Relocation Kit
2005 5.9 QCSB 4X4, Black, stock. Sold but not forgotten
2008 6.7 QC 4X4 Big Horn, Mineral Grey, stock except for K&N. Sold
2002 5.9 24 valve 4x4 , silver, short bed sport. Stock for now
musclecarman is offline
