ECM taking a poop ?? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 08-21-2012, 01:27 PM Thread Starter
I think my ECM is taking a crap on me lets see I've been throwing a few codes for about 6 months map sensor voltage to low and too high and air intake temp voltage too low truck has been running fine until last night my check gauges light came on and my voltage dropped threw a bunch of codes but I think because the system was not charging properly hooked it up to jumper cables and it runs fine as if nothing is wrong with it other than not charging have its got year old battery's and altnator is the Same all got replaced at the same time anybody have any suggestions on where I should go from here thanks fellas
02Raw2500H.O.6sp
Airdog150,BDhp vp44 injectionpump,edgefiltersmia,farmboy100hp injectors,5instrightcutSTACK,
afeIntake horn,BDmanifold,SMARTY,EDGEcompbox,BDstealth cover,phantomIIguages,BD superBturboshortshifterSBDDclutch397hp850tq:party0 18:
justblazespcummins is offline
post #2 of 9 (permalink) Old 08-21-2012, 02:26 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
ECM doesn't control charging of the alternator but the PCM does. You might pull the alternator and have it bench tested for AC noise being that both computers seem to taking on damage from something.
Mopar1973Man is offline
post #3 of 9 (permalink) Old 08-21-2012, 03:07 PM Thread Starter
Thanks mopar man you are extremely helpful on this forum we'll go from there does it sound to you like my PCM could be going or do you reckon this is most likely steming from a bad altnator I'll pull it off and have it checked ASAP
02Raw2500H.O.6sp
post #4 of 9 (permalink) Old 08-21-2012, 06:30 PM
Mopar1973Man.Com
I'm not saying its going to be the answer to the problem but seem rather odd that both computers are going out. Trying to think outside the box a bit.
The Following User Says Thank You to Mopar1973Man For This Useful Post:
justblazespcummins (08-21-2012)
post #5 of 9 (permalink) Old 08-21-2012, 09:35 PM Thread Starter
Trailered it home last night after gettin stuck on 895 in Baltimore md either way batts were dead had enough juice to turn it over once so I pushed it off the trailer pop the clutch started it and it was running fine even charging didn't see how log it would run as I wanted to get that alt checked tomorrow in the am I'll let ya kno how that goes I did notice when it first started doing this yesterday I shut it down to get fuel and it started fine and charged fine for around 80-100 miles then started I could shut it down and start it back up and it would run for 15-20 miles charging then drop either way starting at the alt tomorrow we shall see thanks again
02Raw2500H.O.6sp
post #6 of 9 (permalink) Old 08-22-2012, 02:00 PM Thread Starter
Well alt passed one test on one tester and fail on another tester at diff store replacing anyway we'll see how she runs
02Raw2500H.O.6sp
post #7 of 9 (permalink) Old 08-22-2012, 05:22 PM Thread Starter
So far so good guess we'll see if it stays charging would you say that my MAP sensor and AIT sensor have gone bad seeing as those codes will not go away when she idles when the engine is cold it runs fine for a minute or so the starts gradually reving up untill about 1900-2000 then starts running really funny like spuddering and sounds funny but if you tap the pedal it'll run fine for a min the start doing it again untill it's warm then idles fine
02Raw2500H.O.6sp
post #8 of 9 (permalink) Old 08-22-2012, 05:58 PM
paulb's Avatar
Can you post a list of all the codes that are still being set?
Paul
05 2500 4x4 BBI injectors, UDC Pro, Source Automotive Twins, F1 springs, F1 Cam, Crower Rods,Mitusa, PPE Dual Fueler, Ultimate Transmission, Opie shafts,Isspro gauges - 1015hp
14 2500 4x4 Laramie, Smarty Touch, UDC Pro tuning by me
paulb is offline
post #9 of 9 (permalink) Old 08-22-2012, 08:38 PM Thread Starter
P0112 intake air temp sensor voltage low
P0237 MAP sensor voltage to low
P1693 and we all kno this one
These codes will not clear as soon as I clear code with smarty they come back with out having to turn off and back on I can't make these go away I've been running like this for around 6 months not major difference other than comp box is not working on 3-5 1-2 it works and I can tell a difference when you turn it on and off
02Raw2500H.O.6sp
