Chips/Programmer for Fuel Economy - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 08-17-2012, 08:26 AM Thread Starter
Alan96's Avatar
Have an 01 Ram 2500 Automatic essentially stock that I use to cross 4 mountain passes hauling grapes for my winery. At $4.00/gallon fuel economy is heavily on my mind. Any opinions on a device to help with fuel economy? Increased power or other benefits would be nice but my only real concern is the fuel and the cost of the unit.
2001 Dodge Ram 2500 4x4, Auto Transmission, stock all the way except a set of gauges (Fuel Press, Trans Temp, and EGT) and a Raptor FRRP-100 lift pump.
Alan96 is offline
post #2 of 10 (permalink) Old 08-17-2012, 10:30 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Running Rv275 Injectors and Edge Comp (Wide open) for 13-14 MPG with a 8K travel trailer.
Mopar1973Man is offline
post #3 of 10 (permalink) Old 08-17-2012, 10:34 AM
UtahDodgeCummins's Avatar
Slow it down too, you will suck fuel the faster you go. 62 mph is the sweet spot on my truck, I got 17mpg towing two horses down I-15.
'00 2500 Auto QuadCab ShortBed 105k- Quadzilla Adrenaline, BD performance elbow, 4" straight pipe exhaust, AirDog 100 w/custom bracket, BD Fuel pressure sensor, Autometer boost and pyro, EV2 Fuel Pressure, 55 block
, BD APPS Noise Isolator, BHAF
UtahDodgeCummins is offline
post #4 of 10 (permalink) Old 08-17-2012, 10:55 AM
I was going to mention freeing up the exhaust as well. Either cut the stock pipe and put in a straight pipe or get a 4" turbo back.
1998 Dodge Ram 2500 SLT QC/LB 4x4 CTD
Getting all the parts from the V10 then some...
1999 Dodge Ram 2500 Sport QC/SB 4X4
Ramguy43 is offline
post #5 of 10 (permalink) Old 08-17-2012, 11:18 AM
WillM's Avatar
iTrader Score: 10 reviews
Straight pipe.
And like Utah said, go easy on the skinny pedal.
Ranch Truck: '98.5 QCDRW, NV4500, 2WD, BHAF, Straight Pipe, FASS, Gauges, Steering Box Stabilizer, Ranch Hands
My Truck: '91.5 RCLB, NV4500, 2WD, Leveled, BHAF, 4" Straight, Isspro Fuel Pressure/Boost/Pyro/Tach/Oil, 24V Intake Horn, PS I/C, 3" Intake Plumbing, S362/68/.70 SX-E, THD Competition 6x.013", VE Tuned, Hot Screw, Piston Pump, KSB Spacer, THD Pin, 366 Spring, Valair, A1 Studs & 60# Springs 282HP/692TQ
(w/ stock injectors)
WillM is online now
post #6 of 10 (permalink) Old 08-17-2012, 11:40 AM Thread Starter
Alan96's Avatar
Thanks for the suggestions. I am definitely good with the throttle. I'll look into the exhaust but I really do not want it louder.
Any opinions on: Max Mileage Module for Dodge
Alan96 is offline
post #7 of 10 (permalink) Old 08-17-2012, 02:58 PM
Mopar1973Man.Com
I never tow faster than 55 MPH because of all the up and down hills then all the twist in the road too. But never had a problem hauling 6-8K worth of load and always hitting 13-14 MPG. I just haul a load of scrap metal for a friend down to Payette, ID 240 mile round trip and got 14.2 MPG going down. Then half way home picked up another load and hauled it to New Meadows, ID by the time I hit home I was at 16.5 MPG.
Speed is the number killer of MPG's while towing!
Tires are the second killer of MPG's... More aggressive, wider and taller tires hurt!
Improper use of performance modules.
Good tool to learn how to drive again is a ScanGauge II...
Oh Yeah... Idaho is at $4.229 now and going up quickly...
post #8 of 10 (permalink) Old 08-17-2012, 06:31 PM Thread Starter
Alan96's Avatar
All great stuff. I appreciate all the information. Definitely going to look into the ScanGauge II.
Any opinions on this unit? Max Mileage Module for Dodge
Alan96 is offline
post #9 of 10 (permalink) Old 08-18-2012, 09:12 AM
Mopar1973Man.Com
As a matter of fact price went up again on me... $4.259 now...
Time to tighten up on the driving skills again and push for the long haul numbers once again.
Me-> <- Oil companies
post #10 of 10 (permalink) Old 08-18-2012, 10:10 AM
I did some searching and didn't find much feed back on that chip. A lot of people, myself included, run a power puck. Both are just timing boxes and will help mileage some. I'm sure it's a good product.
99 2500 4x4 FASS 95 3" Synergy coils, Metal Cloak control arms, DOR Shackle flip, BHAF, Power Puck, TST PM3 4" Silverline DAP 7x.009SAC injectors. BD Super B. Autometer Z series Boost, Fuel and Pyro No sway bars or overload springs
kschaper is offline
