Gauges - Dodge Cummins Diesel Forum
Old 07-17-2012, 09:43 PM   #1 (permalink)
Loyal Cummins Fan
natemoses13's Avatar
Gauges
So I installed my gauges today and I have a few questions about them.
Boost - I have the hx35 turbo and it gets 19-20 psi max. Is that normal? Should I desire more? I have a bhaf if that matters.
Fuel pressure - I just installed a new Raptor 100 and a new injector pump. Fuel pressure moves between 15-16.5 at idle which is weird to see such movement. Should that be concerning? As i accelerate, the pressure goes up some. When i give it plenty of throttle, I see as high as 30 psi (which is as high as my gauge reads). During my research on this forum, others have stated that pressure goes down at WOT. Should I be concerned about the high pressure? I would originally think that it is a good thing, but it is opposite what most others talk about having. My injectors are stock and I am probably around 275 HP.
2000 2500 QCLB 5-speed. 3.55 axle. Banks brake, Banks monster exhaust. 100hp injectors. Edge Comp. BHAF. Raptor 100. Isspro mechanical gauges. ScanGaugeII. Need a clutch, suggestions welcome.
natemoses13 is offline   Reply With Quote
Old 07-17-2012, 09:45 PM   #2 (permalink)
WillM's Avatar
iTrader Score: 4 reviews
Boost is normal.
Fuel pressure doesn't sound right. What kind of fuel pressure gauge did you get? Mechanical or electric?
-Farm Truck: '98 24 Valve / QCDRW / 2WD / NV4500 / DTT Assassin / DiPricol / ISSPRO / ScanGauge II / BHAF / 3" Straight Pipe / Tow Mirrors -
WillM is offline   Reply With Quote
Old 07-17-2012, 09:56 PM   #3 (permalink)
Loyal Cummins Fan
It has a pressure sensor at the gas line that sends an electric signal to gauge. So electric. It is located after the filter, right before the injector pump. Feed lines between LP and IJ are 1/2 inch big lines.
Old 07-17-2012, 10:17 PM   #4 (permalink)
WillM's Avatar
When you go to WOT, you should see a 3-5 PSI drop with a Raptor 100.
Personally, I wouldn't trust an electrical gauge. It wouldn't happen to be a Glowshift would it?
The Following User Says Thank You to WillM For This Useful Post:
eforbes (07-31-2012)
Old 07-17-2012, 10:38 PM   #5 (permalink)
aub1895's Avatar
Sounds like your gauge is screwed up. I can't see your raptor doing that. Stock your wastegate should be set at 23 psi so those numbers sound just a little bit low, but not far off. Did you buy a cheap set of gauges?
2001- 4x4 3500, P-PUMP, #10 camplate, cpp 75hp injectors, 62/14 over s475 twins, a1 12mm head studs, 3 piece manifold, 4" exhaust, PAC brake, Fass platinum 150 lift pump, vulcan draw straw, South Bend DD clutch
aub1895 is offline   Reply With Quote
Old 07-18-2012, 06:58 AM   #6 (permalink)
Also, did you use a snubber valve when you hooked up the fuel pressure gauge?
2001 Dodge Ram 2500 2WD Auto 5.9L Cummins: Raptor 150 w/ full 1/2" line kit, Hypertech 3 Stage programmer, BD Boost Fooler, straight pipe, blocked wastegate, BHAF, 5" RSD exhaust, ISSPRO EGT, boost and fuel pressure gauges.
2001 Hypertech Cummins is offline   Reply With Quote
Old 07-18-2012, 08:00 AM   #7 (permalink)
Loyal Cummins Fan
Yes, they are Glowshift. Not sure why I went with them, but I did. Are they really that bad? Several people on here mentioned liking them. I did not use a snubber valve as I did not have one on hand at time of installation. Is that a necessity?
I am wondering if my scenario is possible because I have an upgraded lift pump, the big line kit, the location of sensor is right before the injector pump (post filter), and the injectors as well as everything else is pretty much stock (no box yet either).
Old 07-18-2012, 08:26 AM   #8 (permalink)
Loyal Cummins Fan
Took it for another spin this morning and the only thing that still stands out to me is that the fuel pressure will go as high as 30 psi while I am on the throttle pretty hard. during idle and slower acceleration, the pressure stays pretty consistent around 16-18.
Old 07-18-2012, 12:47 PM   #9 (permalink)
You do need a snubber valve. The VP produces a "waterhammer" effect which kills the gauge senders. You might have got a bad sender because I don't see any way your fuel pressure would go up when you have the pedal down. It would if you had a mechanical lift pump such as a Glacier Fuel Boss but definitely not with an Airdog.
Old 07-18-2012, 03:08 PM   #10 (permalink)
even with water hammer, i dont think you would see 30psi on the gauge. sounds like your gauge is screwed.
DannyMK2 is offline   Reply With Quote
Old 07-18-2012, 06:22 PM   #11 (permalink)
Loyal Cummins Fan
Ok, so throughout the course of the day, the gauge started acting more normal. Would stay around 15 or 16 and then dip to 11 or 12 when I would get on it. Occasionally it would go up to 25 or so too. Is it possible that air in the sensor could be causing that?
Old 07-30-2012, 08:41 PM   #12 (permalink)
Loyal Cummins Fan
I purchased and installed my snubber valve. And it is making no difference. How this snubber valve works is confusing - its just a needle that you thread down - should I have it all the way open or what? My gauge is still all over the place, has my sender gone bad? This is baffling. I know I have decent pressure, because its a brand new fuel pump and vp44; but what the heck? At idle, the thing now reads 30, and when you are driving, the needle goes everywhere and it isn't consistent with the use of the throttle. Any help please?
