47re trouble shifting from 1-2 - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 07-09-2012, 09:59 PM Thread Starter
cummin not strokin3's Avatar
Lately ive been having issues with my
Truck shifting from 1st to 2nd, i have to
Let off and get back on the throttle lightly
For it to shift, i had the local shop drop the
Pan and change the governor solenoid and
The transducer and it still wont shift right,
What am i missing
1997 dodge 2500, diamo17karot,4gsk, 66/74/14 Silver Bullet 5x16 injectors ,ThurenFab track bar, Snow Performance Stage 2, southbend 550 13"flywheel, 0 plate, 5" Str8 Pipe ,AFE BHAF,BD intercooler boots, boost and pyro gauges 2009 dodge 2500 6.7 EGR Delete,4" tbe,H&S XRT, H&S rail plug, H&S sticker on the back window
cummin not strokin3 is offline
post #2 of 13 (permalink) Old 07-09-2012, 11:18 PM
Cumminsedge's Avatar
Check the transmission output speed sensor. It's back of the transmission. It may be reading wrong and not telling the transmission to shift out of first. Mine did the same thing.
Sent from my Autoguide iPad app
Cumminsedge is offline
post #3 of 13 (permalink) Old 07-10-2012, 12:35 AM
VP Moderator
dozer12216's Avatar
tranny speed sensor on left side of extension is very possible. Also adjust 2nd gear band if not done with internal sensor replace.
dozer12216 is offline
post #4 of 13 (permalink) Old 07-10-2012, 05:41 PM
SASdakota's Avatar
BS, the transmission doesn't give two ..... About the speed sensor for a 2nd gear shift. Its all hydraulic in the VB.
It is most likely gov solenoid or more than likely the intermediate band needs adjustment.
2010 RAM 3500 Crew Longbed DRW - CTS2 & ISSPRO EV2 monitoring stuff & some RED parts in the trans. "It is just a tow rig..."
SASdakota is offline
post #5 of 13 (permalink) Old 07-10-2012, 05:43 PM
SASdakota's Avatar
You must have done other things aside from the speed sensor or the speed sensor changed the gov solenoid signal because the 2nd gear shift is hydraulic in the VB. The truck has zero electronics for 2nd gear, only the governor pressure sensor.
post #6 of 13 (permalink) Old 07-10-2012, 06:37 PM
The transmission does give two ..... about the speed sensor. If the computer doesn't see the output rpms of the tailshaft it will not shift out of 1st. If I remember correctly it must reach 1800 rpm at the tailshaft for it shift into 2nd. That is all I did to repair the problem. With a scanner hooked up it was reading all over and not consistent. Put a new sensor in and repaired the problem.
post #7 of 13 (permalink) Old 07-10-2012, 07:07 PM
SASdakota's Avatar
Did your speedo work properly?
Here is why I say that, when I built my transmission there is no electronic control over the 1-2-3 shifts. There is only hydraulic pressure which is governed by the electronic governor. TCC lockup and overdrive have solenoids. You can move your 123 shift points around solely by adjusting your tv cable...
So maybe your speed sensor was causing the governor to change line pressures causing a hang shift without seeing the tv movement to overcome it. But the speed sensor doesn't have direct control over that shift.
post #8 of 13 (permalink) Old 07-10-2012, 07:11 PM
SASdakota's Avatar
OP, if u did a band adjustment, no codes, speedo works, try verifying your tv cable adjustment and see if it shifts better.
post #9 of 13 (permalink) Old 07-10-2012, 07:15 PM
All-in99's Avatar
Mine did same thing the band wound up breaking in half when I had this problem
Sent from my Huawei U8800-51 using AutoGuide.Com Free App
99 eclb 3500 ...gone
01 qcsb 2wd 5 spd, edge drag comp, DAP 175's, isspro gauges str8 pipe and running a lil bit toasty more to come...
All-in99 is offline
post #10 of 13 (permalink) Old 07-10-2012, 10:48 PM
VP Moderator
dozer12216's Avatar
A rise in governor pressure (electric controled) vs throttle pressure causes the 1-2 shift and the 2-3 shift. The trans speed sensor is what allows governor pressure to increase. The vehicle speed sensor (at rear axle) is a input also but perhaps contributes more at higher speed for TCC and OD engagements.
post #11 of 13 (permalink) Old 07-10-2012, 10:59 PM
Thank you I didn't think I was an idiot
post #12 of 13 (permalink) Old 07-11-2012, 12:12 AM
ghostman's Avatar
iTrader Score: 6 reviews
There is hydraulic pressure governed by an ELECTRONIC governor sensor. Something about that just doesn't make sense. If its electronic, it wouldn't make you think it's solely hydraulic, right?? I'm no expert though.
Dads: 2002 QCLB 2500|NV4500 4X4|BD Super B|gauges|banjo upgrade|assassin FP|Quad/V2|S&B CAI|4" TBE|CFM+|heater delete|Flex-a-Lite fans|SB OFEK|Weston's 6 x 0.011" micro-blind SAC|Tunnel Ram|steering box brace|98/99HD Steering
2002 QCSB|rebuilt dash and HVAC|Weston 7 x 0.011"|BD Super B|Edge EZ|4" TBE|billet tappet cover|S&B CAI
Mine: 2002 QCSB 2500|47RH/NV273 hybrid|12V|5x0.016" 155* Westons injectors
ghostman is offline
