What else can it be? - Dodge Cummins Diesel Forum
Old 06-04-2012, 12:34 AM   #1 (permalink)
CumminAtYou's Avatar
Truck just will not start. Replaced injection pump, crank sensor, cam sensor. Getting these codes:
P1689: NO COMMUNICATION BETWEEN ECM & INJECTION PUMP MODULE
P0216: Fuel Injection Pump Timing Failure
Fuel is spraying out of the injector lines real good. Truck just cranks and cranks with no start. All fuses and relays are good. Key is in the keyway and undamaged. Checked the plug on the back of the injection pump and there is power and grounds where needed. Truck will not run even for a second. Batteries are charged and motor is turning over good. What else can it be?
98.5 24v 3500 5 spd, 2in Leveling Kit, Ranch Hands, Raptor 100 w/ Big Lines, Quadzilla Adrenaline w/ Pulse v2, Recon Cab Lights, 5k H.I.D.'s, New Paint, Straight Pipe to 5in RBP Tip, Silencer Ring M.I.A., BHAF, Glowshift FP/Boost/EGT, Alpine Audio-and an empty piggy bank
CumminAtYou is offline   Reply With Quote
Old 06-04-2012, 04:06 AM   #2 (permalink)
chevota84's Avatar
These codes show up the whole time? Did you clear them after you changed parts?
Sent from my DROID X2 using Xparent Blue Tapatalk 2
99 Dodge 24v 5spd, tst comp/smarty, 7x.014's, super b over s475, fass 95
chevota84 is online now   Reply With Quote
Old 06-04-2012, 06:24 PM   #3 (permalink)
so i went back out and checked the codes and it only said the P1693(companion code) and i cleared the codes. I turned it over a few times and checked again and nows there's no codes coming up but still no start
Old 06-04-2012, 06:25 PM   #4 (permalink)
DankCummins's Avatar
Did you make sure your big wiring harness to your vp is plugged all the way on?
2006 F250
Had to do it
Never argue with an idiot, they will drag you down to their level then beat you with experience.
DankCummins is offline   Reply With Quote
Old 06-04-2012, 06:31 PM   #5 (permalink)
dewsdodge's Avatar
an im assuming you bled out the lines clear up to the head?
98.5 Ram 3500 Cab&Chas, NV 4500, rebuilt vp44, 4.10's w/ rear detroit locker, Jacobs exhaust brake, muffler/res RIP homemade air intake Quadzilla Adrenaline w/ Pulse V2, FASS Titanium 95, homemade steering stabilizer, valair sd ceramic/kevlar
dewsdodge is offline   Reply With Quote
Old 06-04-2012, 06:32 PM   #6 (permalink)
Supreme Being
irish power mad's Avatar
Is it even kicking to start, and have you loosened all 6 lines, had to do this before mine would go.
Tits and pistons burn money!!!
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator, half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline   Reply With Quote
Old 06-04-2012, 07:03 PM   #7 (permalink)
plug is connected into vp and all six lines are completely bled at the block. every few cranks it seems like it wants to start for about a second
Old 06-04-2012, 07:18 PM   #8 (permalink)
Supreme Being
Are the cross over tubes in right? if not then they would be letting fuel into the return channel in the head.Oh and one more thing, are the high pressure lines on right, I remember a guy on here a few months ago with the same problem as you and it turned out he had the lines mixed up though how he managed this is beyond me.
Old 06-04-2012, 07:22 PM   #9 (permalink)
torqmonster's Avatar
Do you have spark?
B O T T S R
Pabst Powered Twelve Valver
C o n t a g i o u s D i e s e l I n j e c t o r s
torqmonster is offline   Reply With Quote
The Following 2 Users Say Thank You to torqmonster For This Useful Post:
sportster1208 (06-04-2012), Twistedcummins (06-06-2012)
Old 06-04-2012, 07:34 PM   #10 (permalink)
sportster1208's Avatar
Originally Posted by torqmonster View Post
Do you have spark?
So here's your sign
1999 Ram 2500 standardcab, 2.8 puller
2008 Ram 3500 tow rig
B0TTSR brother of PA chapter
sportster1208 is offline   Reply With Quote
The Following User Says Thank You to sportster1208 For This Useful Post:
torqmonster (06-04-2012)
Old 06-04-2012, 07:40 PM   #11 (permalink)
nah man i have them on just like i took em off. no spark lol. I was driving and it started sputtering and surging and died. We filled it up to a quarter tank and bled the lines with no luck. My dad towed me back to the house and i popped the clutch and it started and would drive in first as long as i would not touch the gas any(if i did, it would die). sounded to us and a few on here to be a vp issue. that is the problem we have been trying to fix this whole time
Old 06-04-2012, 07:42 PM   #12 (permalink)
Crank that thing till it starts!
