Best type of oil - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 04-27-2012, 02:14 AM Thread Starter
AAmolina015.9's Avatar
Best type of oil
So I'm about to do my oil change on my cummins and I've always used royal purple for my other vehicles and I wanna know what Wouk be the best for my cummins any suggestion???? Thanks guys
Quadzilla xzt+, 100hp FBD injectors,ind inj vp44,raptor 150 lift pump,hx35/40 turbo, 2in leveling kit,soon to have 4in lift, 35/13.5/16 cepek, custom off road bumper built by me.
AAmolina015.9 is offline
post #2 of 18 (permalink) Old 04-27-2012, 03:01 AM
PA VICE PRESIDENT
Ramitt's Avatar
A lot of people use rotella. My buddy used royal purple in his truck this time and was like 150.00 That was at his 15% discount at napa. Im to cheap to run that every time. lol
Mitt
2002 2500 SLT 4x4 6 Speed 3.55's. SB Dual Disk ,Fass 150,Edge Juice w/attitude, 150hp injectors, AFE intake,5in str8 piped exhaust,20% window tint,Leveled with 33's,Halo head lights w/55watt hid's, 35watt hid fog lights,Ram Air Hood,High idle mod.
Dynoed at 420 hp - 960 ft-lb
Ramitt is offline
post #3 of 18 (permalink) Old 04-27-2012, 09:43 AM
its like splitting hairs asking a question like this. everyone has a preference as to which is better. ive used a few and they all seem good to me. i guess personally, i use valvoline blue or mobil delvac the most.
DannyMK2 is offline
post #4 of 18 (permalink) Old 04-27-2012, 10:22 AM
Gyropilot
JLandry's Avatar
I've been using inexpensive Chevron Delo for many years, which can be purchased for a great price at warehouse stores like Costco or Sam's Club, I change it and the filter every ~7500 miles, and I've been getting excellent oil analysis reports from Blackstone Labs.
Best regards,
John L.
Sent from my iPad using Tapatalk HD
2014 Ram 3500 Laramie 6x6 (Dually) Crew Cab LB, Aisin Tranny, 4.10 Axles, Factory 5th/Goose Prep - Born: 1/22/2014 at 3pm
Gone (but not forgotten): 2001 Dodge 2500 Laramie SLT 4x2 QC LB, Goerend 47RE, 4.10 axle
Retired and RV'ing full-time in a 2007 Arctic Fox 25R travel trailer
JLandry is offline
post #5 of 18 (permalink) Old 04-27-2012, 01:25 PM Thread Starter
Well I keep getting told with diesel I need to run a specific type of oil and blah Blah that's why I ask, so if it's just like normal then that answers my question
post #6 of 18 (permalink) Old 04-27-2012, 01:27 PM
cummminsV12's Avatar
its always a personall choice.. I like rotella.. I use the semi synthetic..
01 ECSB SPORT-Quad4K,DTT Built47re/48RE inside,AD2-165,RADbox,PusherIntake,7x.012w/lift,Silver64,ARPStuds
cummminsV12 is offline
post #7 of 18 (permalink) Old 04-27-2012, 01:29 PM
clatterbuck2000's Avatar
I run valvoline premium blue. just and fyi fer fellers that dont know.....valvoline premium blue was orionally cummins premium blue. this oil was designed to reduce carbon buildup in the older 855's. valveoline makes it per cummins recipe and specs. my .02
00 QCLB CTD Nv4500-steering brace-Isspro & Autometer gauges-BHAF-Airdog DF165
-South Bend DD3600-o-ringed-studded-DAP 7x.010 sac's-Borg S363Snow W/M-TST COMP/TS MVPLotta smoke...Not a whole lotta go
cracked 53 block Next to come: Engine under construction
clatterbuck2000 is offline
post #8 of 18 (permalink) Old 04-27-2012, 01:40 PM
dixon700's Avatar
As long as its 15w-40 and cj-4 or higher certified its a good oil to run. I run Mobil delvac 1300super with a half gallon of Lucas. My last oci was about 8500 miles and blackstone labs said its showing better wear than an equivalentengine with 6500 miles so this time around I'm going for 10k. Also I put in 24oz motor kote I'm gonna start trying that every 3 oil changes. Filters also have a lot to do with it. This oil change is going to be a Baldwin fuel and a donaldson oil filter.
04.5qcsb 3/4hd soon kilduff shifted raychem built 47re isspro adii motorsport 100%over and 10.6cp3 & bypass CPP stainless diesel63 over s475 trac bars mishimoto Hamilton pusher arp smarty ssr 4"-7"stacks 4.10's 6"lift 37"toyo mts eagle dynatrac
dixon700 is offline
post #9 of 18 (permalink) Old 04-27-2012, 01:46 PM
rhagfo's Avatar
Yes you need an oil designed for Diesel engines, Delo 400 LE is one such oil, Valvoline premium blue is another.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 296K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #10 of 18 (permalink) Old 04-27-2012, 01:49 PM
i actually used to be religous with rotella. buuuuuut since im a cummins employee i figure i might as well stay loyal to the cause with valvoline
post #11 of 18 (permalink) Old 04-27-2012, 02:27 PM
Western WA President
jigabop's Avatar
I run AMSOIL and change every 10-15k miles. other than rear ends and power steering, everything else in the truck is AMSOIL.
the rear ends and PS fluid will soon be changed to AMSOIL when I have the gear ratios swapped.
Like what was said above, its personal preference really. just stick with a 15w-40 CJ-4.
haven't noticed a difference between oils in cummins, but in my 2002 VW Jetta TDI, I tried running DELO 400 in it and the engine got pretty loud, drained it changed filter and put synthetic back in and it got a LOT quieter. seemed to be a lot happier with synthetic. I was running mobil 1 in the jetta.
00 24v powered by the high performance "53" block and "Unicorn Injectors" 576hp/1285tq 8/10/2013
2004 Jetta TDI 5spd Malone S1 + dyn EGR/idle tune
Originally Posted by DieselDon16 View Post
my truck is literally full of Panties already...
Originally Posted by 'strokeThis_'07 View Post
I'll admit, I was sitting here giggling like a little girl
jigabop is offline
post #12 of 18 (permalink) Old 04-28-2012, 03:04 AM
Twistedcummins's Avatar
I'm happy with Rotella 15-40 been running it for the 25k I've put on the truck since buying it. It's relatively cheap and pretty commonly available. Only complaint I have is the faint smell from towing heavy but like others have said its all personal preference
99 QCSB 4x4 auto/Edge/Airdog/Isspro
Originally Posted by USARMY12V View Post
With a 47RE it's impossible to tell. It's easier diagnosing what's wrong with a woman.
Twistedcummins is offline
