1999 Dodge transmission problems - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-15-2012, 06:50 PM Thread Starter
I had issues with this truck not going out of first or 2nd gear last year i changed governer pressure solenoid,transducer, adjusted the band on the outside of the case. I also changed the apps sensor and vss. The truck shifts through all the gears but i have to over rev it and let off the gas to shift. I am not sure if it is electronic or what but i have been driving it for a while. I believed its 47re. This truck has been converted to a 3500 utility bed and has about 190k. I am thinking of selling this truck too hd for me right now. Is this electronic or is my 2nd gear band gone? h
ironmanjohn25 is offline
post #2 of 10 (permalink) Old 04-15-2012, 10:11 PM
BC-12Valve's Avatar
Location: Home: Raincouver, BC....Work: Wabasca, Alberta
Try a shift sensor.
2002 2500 Sport 534/1170 Sold
1991 RCLB Toyota 4x4, 5spd, BFGs, 22re
2005 Subaru Impreza STI
BC-12Valve is offline
post #3 of 10 (permalink) Old 04-16-2012, 10:30 AM Thread Starter
I didnt know there was a shift sensor? I thought I had asked the guys at the dealer? I think maybe it could be valve body itself but don't know how to diagnose
post #4 of 10 (permalink) Old 04-16-2012, 10:33 AM
BC-12Valve's Avatar
My buddy had an auto truck and his truck wouldn't shift out of 3rd gear. Figured out it was a shift sensor. Try your valve body..drop the pan and take a look. If all the cables are frayed and what not you know you have a problem :p!
post #5 of 10 (permalink) Old 04-16-2012, 02:52 PM
Got P7100?
mathews8pt's Avatar
iTrader Score: 9 reviews
No such thing as a "shift sensor". They must have been reffering to something else.
If all that has been replaced and you still have an issue id say you have a pressure leak in the trans. coud be a seal or a worn valve in the vb.
Hobie
2000 QCSB, 180 pump, 6x.013's, maxspool 2.5, s364/s480, tranmission built by me, AD150
11.23 @ 121mph
mathews8pt is offline
post #6 of 10 (permalink) Old 04-16-2012, 06:54 PM Thread Starter
I see vb going for 300-600 am i better off just having it all rebuilt? My plan is to sell the truck but i know how hard it can be to sell it when its operating like this. It shifts but you have to release throttle. Not sure if its worth at 300-600 dollar gamble of throwing vb. I never adjusted the band inside the one that is under the valve body. I only adjusted the outside band. Not sure if this matters. I think the outside is 2nd gear band.
post #7 of 10 (permalink) Old 04-16-2012, 08:00 PM
Jonny_559's Avatar
My '99 was doing the same thing, it was the speed sensor on the tranny.
'99 4wd ext cab,HBS leveled, silencer ring removed, 5" straight pipe w/ stack, BHAF, airdog II, edge w/CTS.
Jonny_559 is offline
post #8 of 10 (permalink) Old 04-16-2012, 08:36 PM
check the kick down cable
95 3500 dodge v10/ 93 2500 dodge diesel
rdhawk is offline
post #9 of 10 (permalink) Old 04-16-2012, 09:52 PM
pepsi71ocean's Avatar
read my article here and it should help you out
Mopar1973Man's Dodge Cummins Articles - Automatic Transmission Diagnostic Chart
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is online now
post #10 of 10 (permalink) Old 04-16-2012, 11:08 PM
BC-12Valve's Avatar
*speed sensor* oops.
