1999 lift pump install step by step - Dodge Cummins Diesel Forum
post #1 of 1 (permalink) Old 04-11-2012, 09:48 PM Thread Starter
So after days of looking on 5 different forums i finally found the best step by step write up on how to change the lift pump on a 1999 24v.
due in part to this link. FAQ
I will be installing a DDRP-02 tomorrow morning I will let you all know how accurate this is.
*note* I have never worked on a diesel and will be doing this all based on text.
and mechanical ability.
Procedure for a 1999 Ram
NOTE: You may be able to improve this but this is exactly what we did and changed two pumps in less that two hours)
TOOLS: 17 mm wrench & socket, 10 mm wrench & socket, 7/16 socket, inch socket
*Lay a non-conducting material over the battery posts (fender cover, etc)
*Make sure you have the new pump and eight banjo washers
*Remove the two banjo bolts from top of the fuel filter housing using a 17 mm wrench
*Remove the old banjo washers from the fittings
*Disconnect the water in fuel sensor at the bottom of the fuel filter housing
*Disconnect the fuel filter heater element plug at top of the filter housing
*Remove the drain tube from the bottom of the filter housing drain
*Remove the two manifold bolts holding the filter housing to the intake manifold
*Remove the entire filter housing being careful not to drain the fuel from it
*Remove the banjo bolt holding the solid fuel line that goes the inlet of the filter housing using a 17 mm wrench
*Remove the banjo bolt on the suction side of the lift pump
*Remove the 10 mm bolt holding the suction line to the pump bracket
*Unplug the electrical connector to the lift pump
*Remove the three nuts holding the lift pump in place, socket inch I believe
*Remove the lift pump
*Install the new pump and the two back nuts loosely just to hold the pump in place
*Install a new banjo washer on the suction bolt
*Install the bolt in the suction fitting and install another washer on the bolt
*Thread the bolt into the pump suction while the two nuts are loose on the pump
*Connect the power to the pump
*Install the cable support and the third nut on the pump bracket
*Tighten the pump suction banjo bolt, and the three nuts holding the pump in place
*Tighten the bolt holding the suction hose in place
*Install a washer on the pump discharge banjo bolt
*Install the bolt in the discharge tubing and install another washer
*Install the discharge to the pump but do not tighten
*Set the fuel filter housing back in place with the two manifold bolts but do not tighten
*Install a washer on the filter inlet banjo bolt
*Install the bolt far enough to get another washer on the other side and thread the bolt into the filter inlet
*Install a washer on the filter outlet banjo bolt
*Install the outlet banjo bolt in the outlet tubing and install another washer on the other side
*Thread the outlet bolt into the filter housing
*Tighten to two filter housing intake manifold bolts
*Tighten the two 17 mm inlet and outlet bolts on top of the housing
*Tighten the 17 mm bolt on the discharge of the lift pump
*Connect the fuel grid heater wiring at the top of the housing
*Connect the fuel in water wiring to the bottom of the housing
*Install the plastic housing drain tube
*Loosen the inner or outer plug on top of the housing with a 7/16 socket
*Bump the key like you are going to start the truck and bleed the system (may need to do this several times)
*Do a double check and make sure everything is tight and there are no leaks
bigmke184 is offline
