Old Fashion Moth Balls in Diesel Fuel - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 04-04-2012, 09:34 PM Thread Starter
I know that a sucker is born every minute. Ran into a old gent today while filling up. He was driving a F350 and told me he had been putting 1 Old Fashion Moth Ball per 3 gal of fuel since he had 8k miles on his truck. The truck now has 110k miles on it with no problems. Claimed he increased his mpg by 2-3 mpg's. I did some research online and found more negative than positive comments. I did find a formula of 1 ball per 4 gals. Is anyone doing this with a Dodge Diesel ???
Mohok is offline
post #2 of 22 (permalink) Old 04-04-2012, 09:44 PM
joeschmo's Avatar
never heard this...very interested though
joeschmo is offline
post #3 of 22 (permalink) Old 04-04-2012, 09:47 PM
04.5CTDlaramie's Avatar
wtf? guess if i start seeing moth holes in my tank ill look into it...lol.
04.5 2500 Laramie,4x4,3" level w/bilsteins,17's w/35s,4.10s,63/68/.80,smarty tntr,floor it cp3,edge ez,water meth,straight pipe w/cat,s&b intake,elbow,raptor 150,big line,billet trans,gauges boost,egt,fp,rp,539hp/979tq
04.5CTDlaramie is offline
post #4 of 22 (permalink) Old 04-04-2012, 10:16 PM
pepsi71ocean's Avatar
file this under the things that you shouldn't do.
Along with adding
used motor oil
used transmission fluid
marvel mystery oil..
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is offline
The Following User Says Thank You to pepsi71ocean For This Useful Post:
dixon700 (08-11-2013)
post #5 of 22 (permalink) Old 04-04-2012, 10:58 PM
VP Moderator
dozer12216's Avatar
Somewhere I recall some talk about doing this. It escapes me now, however.
I beleive it was a cheap gasoline octane enhancer.
Yea! that's it. Got no ideal if worked on gas and definitelly no ideal what it do to diesel. He may have a tank filled half way with partially disolved white balls.
dozer12216 is offline
post #6 of 22 (permalink) Old 04-04-2012, 11:06 PM
WillM's Avatar
iTrader Score: 10 reviews
Something tells me not to do this. I don't know what, though. . .
Ranch Truck: '98.5 QCDRW, NV4500, 2WD, BHAF, Straight Pipe, FASS, Gauges, Steering Box Stabilizer, Ranch Hands
My Truck: '91.5 RCLB, NV4500, 2WD, Leveled, BHAF, 4" Straight, Isspro Fuel Pressure/Boost/Pyro/Tach/Oil, HX35, 24V Intake Horn, PS I/C, 3" Intake Plumbing, THD Competition 6x.013", VE Tuned, Hot Screw, Piston Pump, KSB Spacer, THD Pin, 366 Spring, Valair, A1 Studs & 60# Springs 282HP/692TQ
(w/ stock injectors)
WillM is offline
post #7 of 22 (permalink) Old 04-04-2012, 11:16 PM
I think you should experiment and let us know how it goes. Perhaps start with 1 mothball & increase to say...10 or so. Be sure to log & hand calculate mileage. We'd also need to know the brand and composition of the moth balls.
Perhaps buy a mothball factory or come out with your own brand. The slogan could be "My moth balls keep my Cummins cummin." or "Mothballs in my Cummins gits mah motor hummin."
2000 LWB, Quad Cab, 4x4, NV4500, AirDog, Gauges, Thuren Track Bar, Lost crappy AGR and A1-Cardone steering boxes. RedHead is the best so far but truck has stopped returning to center. Hopefully, I'll get to it soon.
Junkman is offline
post #8 of 22 (permalink) Old 04-04-2012, 11:19 PM
VP Moderator
dozer12216's Avatar
Not me. I chicken and proud of it on this project.
post #9 of 22 (permalink) Old 04-04-2012, 11:24 PM
I believe they contain Naptha .
2005 4 door short bed 4x4 Auto . 3.73 gearing . 6" SuperLift and 35's . 145k
2001 2500 Auto Trans 3.55 rear Reg Cab 4x4 . Mostly stock at 230k
24hrsparkey is offline
post #10 of 22 (permalink) Old 04-05-2012, 03:04 AM
1stgen3rdgendodge's Avatar
I've heard of old time racers putting moth balls in the tank in their gassers to get a little extra boost. Old moth balls though. None of the stuff they sell these days though. Never heard of anybody doing it with a diesel though.
01 2500 QCSB 4x4 - NV4500 Swap, 3600# SD from Kenny's, Quadzilla ADR 4k, 150HP Jammer Nozzles, RSD 4" Down Pipe-5" Straight Pipe, AEM CAI, Raptor 150, Big Line Kit Tank to VP, Leveled, Recon Smoked Cab Lights (110# Springs, HD Rods, Head Studs, in the works)
1stgen3rdgendodge is offline
post #11 of 22 (permalink) Old 04-05-2012, 06:55 AM
Blue2003's Avatar
X2 on the olden day gasser cars.
95 r.c.l.b.12 valve..bhaf..siliencer ring m.i.a..stock p-pump..3.54's..BD Trans...BD Convertor...BD exhaust brake..BD AutoLoc..
Blue2003 is offline
post #12 of 22 (permalink) Old 04-05-2012, 07:19 AM
mothballs contain the same ingredient used in napalm .....a highly explosive gas ...remember vietnam .........i know it works in the race cars but in a diesel ???
2002 2wd 6-speed 2500 ext,cab 8 ' box
bigmike is offline
