47re problem. 1,2, &r are fine. Won't drive in D - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 03-16-2012, 10:36 AM Thread Starter
I've done some searching without much luck on where to look to first. The tranny has about 4k miles on a fresh rebuild with dpc super single, dtt shift kit and billet acumulator piston and servo. It hasn't had any issue until last night. I was in a yard and had to accelerate pretty hard to get unstuck. I noticed it seemed to be sluggish from a stop and reving higher than normal and wasnt shifting at, so I limped it home as it was within a few miles and tranny temp was staying normal. Tranny fluid is full and looks clean still, temp last night was under 190.
This morning I started it, in D it idle surges but will drive fine if I shift to 1 and 2. As soon as I shift into D it seems to buck and idle erratic. It also feels like its loosing power. It does it at all rpms and speeds when shifting from 2 to D.
Speedo still works and no lights on the dash. R is normal
I'm new with autos and dodges so I just need pointed in the right direction, Thanks.
98.5 rclb 4x4
03 Evo 10.6@143
wheatley is offline
post #2 of 5 (permalink) Old 03-16-2012, 12:52 PM
sportster1208's Avatar
You need to have it checked for codes first.
1999 Ram 2500 standardcab, 2.8 puller
2008 Ram 3500 tow rig
B0TTSR brother of PA chapter
sportster1208 is offline
post #3 of 5 (permalink) Old 03-16-2012, 01:26 PM Thread Starter
Thanks, I forgot these trucks are obd2. I have a scanner in the garage and these are the 4 I came up with.
P0743 Torque Converter Clutch Circuit Electrical
P0602 Control Module Programming Error
P0463 Fuel Level Sensor Circuit High Input
P1693 Turbo Charge Control Circuit Malfunction
98.5 rclb 4x4
03 Evo 10.6@143
wheatley is offline
post #4 of 5 (permalink) Old 03-16-2012, 02:20 PM
Read this
47R No D1 only D2 and Drive
post #5 of 5 (permalink) Old 03-17-2012, 10:48 AM Thread Starter
When I bought the truck it had a lock-up switch installed. I was told it was disconnected so I never payed attention to the orientation to the switch. It must have gotten bumped when I was looking for something the other night. I realized how it felt when I went from 2 to D in the driveway and it pulled like it does when the tc was locking up, instantly I realized it had to be that switch. Thanks for the help anyways sportster1208.
98.5 rclb 4x4
03 Evo 10.6@143
wheatley is offline
