Sis Put Gas In My Cummins!!!!!!! Help - Dodge Cummins Diesel Forum
post #1 of 110 (permalink) Old 02-14-2008, 10:43 PM Thread Starter
it is bad i know she drove it 15-18 miles before it quit, what should i expect??????? damage to vp-44????? engine???????
jasoncrydn is offline
post #2 of 110 (permalink) Old 02-14-2008, 10:49 PM
bigblue24v's Avatar
if it actually died then worst case would be cylinder/piston damage
whats weird is the gas cap says diesel fuel only as well as on the dash board..it must be a tricky one to pull off
i hope its not too bad
2001 RAM 2500 4x4 QCSB - Garmons Diesel, FCDP, turbomatt's DP, carli, Thuren, 305/50 Toyo A/T, KMC XDs, FCDP traction bars , AFE, Edge, Auto Meter, Airdog, FBD, Mag-Hytec. PPump, twins and 11's under development
bigblue24v is offline
post #3 of 110 (permalink) Old 02-14-2008, 10:52 PM
Banned
I used to work for a construction company and the foremans managed to do it on a regular basis..
Of course they never drove it w/gas so I can't help ya jasoncrydn...
awenthol is offline
post #4 of 110 (permalink) Old 02-14-2008, 10:52 PM Thread Starter
i guess one side of the pump was gas one was diesel. it will restart if i use starting fluid, i thought it was a lift pump issue at first. but does not want to idle , wont restrat if it dies
post #5 of 110 (permalink) Old 02-14-2008, 10:54 PM
dirtyboots707's Avatar
ther idiots i work with like to fill the diesel cans for the skid steer with gas and then the dump it in
it happens about twice a week and my boos still wont fire them
2004 crew cab dually 4x4
dirtyboots707 is offline
post #6 of 110 (permalink) Old 02-14-2008, 10:54 PM
bigblue24v's Avatar
i would say flush the entire fuel system and refill it if it runs at all take it to the closest diesel mechanic and have it checked out
did you hear any really bad noises?
post #7 of 110 (permalink) Old 02-14-2008, 11:00 PM Thread Starter
no when it starts it sounds fine, just idling up and down and stalling. i thought the lift pump was bad , when i tried to check the pressure i smelled gas and no pressure from the pump either
post #8 of 110 (permalink) Old 02-14-2008, 11:01 PM
flush system out put good diesel back in and some cycle motor oil restart and let it idle for a period then as stated take in and run codes on it
hope all turns for the good
99 Dodge Quadcab 24valve Banks intake boost pyro
GoldenValley Az.
dwaymar is offline
post #9 of 110 (permalink) Old 02-14-2008, 11:02 PM Thread Starter
im gonna drain everything tommorrow and fluch and fill it with DIESEL , was just wondering if anybody had any expieriance with this before
post #10 of 110 (permalink) Old 02-14-2008, 11:24 PM
lvin4jc's Avatar
Wow, that stinks man, hope you get it all worked out ok.
2001-4X4-47re-3.55 gears-Amsoil 4510-Isspro triple gauge pod- Leveling kit-Straight piped-Debadged - 240,000+ Miles and counting
lvin4jc is offline
post #11 of 110 (permalink) Old 02-14-2008, 11:32 PM Thread Starter
thanks that really helps...........
post #12 of 110 (permalink) Old 02-14-2008, 11:44 PM
Whistler's Avatar
Let us know how it turns out!
97 3500 4x4 Ext. cab, Goerend Tranny & TC, 15* timing, #10 plate full forward, autometer gauges, lock up switch, prime loc, Amsoil Nano, straight piped, posi-lok, lots to come
Whistler is offline
