Map sensor voltage too low? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 02-24-2012, 09:16 AM Thread Starter
My check engine light has been on and I plugged my Smarty in and it said the map sensor voltage too low. Does anybody know what that means and what I can do to fix it
Sent from my Droid using Tapatalk
1999 24v built 5 speed SB dual disk clutch, ATS 3 piece man, turbo, 150 injectors, smarty stacked with edge drag comp with hot unlock
12v_bulach is offline
post #2 of 4 (permalink) Old 02-24-2012, 09:50 AM
Gyropilot
JLandry's Avatar
What was the specific trouble code?
Sent from my iPad using Tapatalk HD
2014 Ram 3500 Laramie 6x6 (Dually) Crew Cab LB, Aisin Tranny, 4.10 Axles, Factory 5th/Goose Prep - Born: 1/22/2014 at 3pm
Gone (but not forgotten): 2001 Dodge 2500 Laramie SLT 4x2 QC LB, Goerend 47RE, 4.10 axle
Retired and RV'ing full-time in a 2007 Arctic Fox 25R travel trailer
JLandry is offline
post #3 of 4 (permalink) Old 02-24-2012, 10:07 AM Thread Starter
That's what it came up as..
post #4 of 4 (permalink) Old 02-24-2012, 11:50 PM
CoalRoller's Avatar
Voltage low is a short to ground or a shorted sensor. Voltage high would be an open circuit caused by a bad connection, broken wire or bad sensor.
If you ever have current faults (I don't know if cummins uses them). Current high or above normal is a short circuit and current low is an open circuit.
You can disconnect the sensor and see if the code changes. If it changes to voltage high with the sensor unplugged the sensor is bad. If the code doesn't change you have a wiring issue.
2002 6 speed, Edge Drag Comp, DAP 100s, Phatshaft 62/65-14, ARP 425's, Valair Kevlar/ceramic single, FASS 95
CoalRoller is offline
