vp44 shutoff solinoid? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 02-12-2012, 08:40 PM Thread Starter
So the truck cranks and cranks but dosent fire. lift pump runs like it should a couple of seconds with the key on and tenty something after bumping the starter. got fuel to the injector pump. Key trick gave me a p1693 and nothing else. Plugged it the scanner and found a lift pump code. p0230 ? while looking at live data the fuel shutoff solinoid is not turning on. Once in a while it goes on for a second and back to off. Checked wiring and connections and found nothing abnormal. Is the shutoff a sevicable part or is the pump junk or am I looking in the wrong spot? As always any help is greatly appreciated! Thanks, Kyle
Truck; 2001, 2500, QC, 6-speed, 4x4, Debaged, Edge juice w/attitude, 4" magnaflow, AEM bruteforce, Glacier 392, Prodigy, B&W gooseneck Commuter; 95 Geo metro 3cyl, 5 spd, tow package. be jealous
SILVER5.9 is offline
post #2 of 13 (permalink) Old 02-12-2012, 09:33 PM
rhagfo's Avatar
No fuel shut off solenoid on the VP$$, the VP$$ has a relay (called Fuel Pump) in the power center under the hood. I believe that the power to closed that relay coms from the ECM, just like the power for the Lift Pump. There are several with the same part number and are interchangeable.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 298K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #3 of 13 (permalink) Old 02-12-2012, 10:09 PM
Gyropilot
JLandry's Avatar
Questions:
What happen just prior to this problem starting? For example, was any maintenance or were any modifications done, etc.?
What is the fuel pressure at the VP44 fuel inlet when you bump the starter to activate the lift pump?
Have you verified the 14ga red/light green wire at the VP44 connector has 12v power when the ignition key is turned on?
Regards,
John L.
2014 Ram 3500 Laramie 6x6 (Dually) Crew Cab LB, Aisin Tranny, 4.10 Axles, Factory 5th/Goose Prep - Born: 1/22/2014 at 3pm
Gone (but not forgotten): 2001 Dodge 2500 Laramie SLT 4x2 QC LB, Goerend 47RE, 4.10 axle
Retired and RV'ing full-time in a 2007 Arctic Fox 25R travel trailer
JLandry is offline
post #4 of 13 (permalink) Old 02-13-2012, 10:43 PM Thread Starter
Haven't done anything to the truck for awhile other than oil, filter, and fuel filters. haven't had the edge hooked up in over a year. Will try to check power and fuel psi this week. Thanks, Kyle
post #5 of 13 (permalink) Old 02-17-2012, 12:57 AM
Just asking why aren't you using the edge??
2001 QCSB 2500 HO 245hp 6sp, K&N filter, Raptor 100 (FRRP) Lift Pump, and lift pump warning light.
Elevatorman is offline
post #6 of 13 (permalink) Old 02-27-2012, 10:57 AM Thread Starter
Finally got some days off and gonna see ifI can get it runnin'. Took the edge off cause it needed to have a smog check done. I was the first of anyone I knew to have it done and wanted to pass. I had heard that the truck would fail with a programer. Loved it when it was on there and will hook back up.
post #7 of 13 (permalink) Old 09-19-2012, 01:29 PM
harfordcountyfuzz's Avatar
Im having a similer issue and could use some help. had ECM replaced almost a year ago, no problems.....till now. every once and a while the truck will crank and not fire, even after multiple times cycling the key. i can hear the humm of the lift pump and i wait for the Wait to Start lamp to go off before cranking. it never fails that AFTER i put a call into AAA, it'll fire right up and run fine (smoothe, no smoke, no extra noisem, etc.). Then it'll start fine for a few weeks, then do it again. Any suggestions? I wanna have an idea when i take it to the shop.
1999 RAM 2500
5sp. man. (NV4500); 24 valve; 4x4; BHAF air filter; rest stock; pics will be here sometime.
harfordcountyfuzz is offline
The Following User Says Thank You to harfordcountyfuzz For This Useful Post:
kendrickDan (10-01-2012)
post #8 of 13 (permalink) Old 10-01-2012, 02:43 PM
kendrickDan's Avatar
I have exact same problem and would like an answer. My raptor pump is less than 2 months old and bout 3 times out of a week I go out there and wont start. pump works fine I wonder if it has somthing to do with a fuel shutoff. I havnt found any leaks at all.
kendrickDan is offline
post #9 of 13 (permalink) Old 10-01-2012, 02:51 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Lift pump directly controlled by the ECM. (No relays)
As for the VP44 its power is controlled by the ECM and Fuel Pump relay in the PDC.
Mopar1973Man is offline
post #10 of 13 (permalink) Old 10-01-2012, 02:52 PM
if it's a simple relay, i may just cough up the 10$, replace it and if i never have the problem then great.
1999 RAM 2500
post #11 of 13 (permalink) Old 10-01-2012, 02:58 PM
sorry mike, i was trying to reply to *kendrickDan*. as far as your post, is there a relay that controls fuel to the VP44 that coulda crapped out?
1999 RAM 2500
post #12 of 13 (permalink) Old 10-01-2012, 02:59 PM
Never mind mike, i opend my eyes and read your WHOLE post and think i answered my own question
1999 RAM 2500
