40+ PSI on hx35? - Dodge Cummins Diesel Forum
 2Likes
post #1 of 19 (permalink) Old 02-05-2012, 12:45 AM Thread Starter
01_Black_Cummins's Avatar
40+ PSI on hx35?
Before I installed my quadzilla, I ran with a superchip, then a Smarty. I usually made 20-25 psi of boost. But is a whole new ballgame after the quadzilla. My isspro boost gauge tops out at 40 and when the needle pegs out, the Turbo still sounds like its spooling. The boost gauge on the quad went as high as 48. Does this mean my wastegate is plugged off? What psi range can the hx35 handle without grenading?
Thanks for the help,
Eric
01 QCLB 4x4|180P-Pump|FirepunkTrans|WS 7x.013's|ED 63/S477|SteedSpeed|110# Springs/Rods|Traction Bars|Airdog|Fire Ringed|ARP Studs|Isspro|Fluidampr|5"Exhaust
00 QCLB 4x4|NV4500 Swap|Valair|Quadzilla|Fass w/Sump|Gauges|4" Duals
01_Black_Cummins is offline
post #2 of 19 (permalink) Old 02-05-2012, 01:02 AM
1stgen3rdgendodge's Avatar
Wow 48psi is pretty high. 35psi is max for the HX35. I'm assuming that your running a boost elbow. I'd try adjusting that and see if you can get that pressure lowered with that. If that doesn't help and it keeps building boost the wastegate may be frozen shut or plugged.
01 2500 QCSB 4x4 - NV4500 Swap, 3600# SD from Kenny's, Quadzilla ADR 4k, 150HP Jammer Nozzles, RSD 4" Down Pipe-5" Straight Pipe, AEM CAI, Raptor 150, Big Line Kit Tank to VP, Leveled, Recon Smoked Cab Lights (110# Springs, HD Rods, Head Studs, in the works)
1stgen3rdgendodge is offline
post #3 of 19 (permalink) Old 02-05-2012, 01:40 AM Thread Starter
Yeah, I was pretty shocked to see that number too... I have not messed with the Turbo whatsoever. Not sure what the previous owner did to it. And it seems when i have the quad turned all the way up, I have all that boost and not so much power. The Turbo spools insanely fast but soon after to hits 30+, i lose most ofy top end power and it just seems like all that boost is just a waste I guess. Do you Think its out of its efficiency range? If i turn the box down to level 5 or so, I have great power in top end and the boost is synched up with the power and speed if you know what I mean.
post #4 of 19 (permalink) Old 02-05-2012, 01:57 AM
Yeah anything over 35psi is out of that turbo's efficiency range and your just now blowing hot air. Thus why it feels like your losing power. Turning the box down you aren't flow as much fuel so I'm sure your pressure is down lower. So with that said things to look for are that the wastegate is hooked up. If it has a boost elbow on it try adjusting that and see if you can get that pressure down to 35psi or a little lower and if that doesn't worked I'd say it has either been plugged off or possibly it's frozen shut. Sounds more like it's just not opening up.
post #5 of 19 (permalink) Old 02-05-2012, 02:25 AM
mountianman69's Avatar
What he said
Sent from my Autoguide iPhone app
(Built by The Pit Stop) 2001 QCSB 4x4 35" Pro comps TWINS superB over S475 with CPP 7X12 SACs with lift Quad 4K Phantom2 guages AIRDOG 150(THE GOOD FITTINGS NOT THE CRAP ONES) Valair 800hp ceramic DD billet input shaft Hamilton push rods and Hamilton springs Stainless diesel twin kit (fits perfectly!!) stainless diesel adjustable waste gate And thanks to Optima 2 Brand spanking new Red tops as a truck warming gift!
Originally Posted by DieselDon16 View Post
Im not gonna be a Bachleor silly, Im gonna marry you!!
"Im Forever yoouuurrrsss, Faithfully.........Nick"
mountianman69 is offline
post #6 of 19 (permalink) Old 02-05-2012, 02:32 AM Thread Starter
Would that also explain why my Turbo whistle is so loud? I've rode in many different trucks with both hx and hy35's and theirs is nothing compared to mine. I have a 4 inch straight pipe and no silencer ring with a K&N Cold air intake and filter. I get alot of compliments on how badass the Turbo sounds but I'm starting to wonder if something could possibly be wrong with it. Its only going to be on there for a little longer. 64mm coming in the near future.
post #7 of 19 (permalink) Old 02-05-2012, 02:39 AM
It's the open air filter and the silencer ring Mia ours sounds crazy loud to most people because we don't have the stock air box but I am sure you being at 45 psi is making it a bit louder
post #8 of 19 (permalink) Old 02-05-2012, 10:14 AM
Yeah I could imagine that at 45psi that thing would be screaming!! Mine is pretty loud as well. Never use to get much sound out of the exhaust though till I ditched the stacks and put the straight pipe on.
post #9 of 19 (permalink) Old 02-05-2012, 10:16 AM
Banned
just an FYI, a stock boost eblow ill be completly open. there are some boost elbows that are non adjustable and look the same on the out side but they hae a very small orfice on the insde.
also once a HX35 hits arount 30-31psi they make a completly different sound then at lower pressures.
Mopar1973Man likes this.
cumminsdog is offline
post #10 of 19 (permalink) Old 02-05-2012, 12:47 PM Thread Starter
The turbo whistle at 40+ is nothing compared to When I shift. All that pressure blows off and instead of making a "sighing" it makes a very loud pop. Sounds like someone's under my hood spraying an air hose.
post #11 of 19 (permalink) Old 02-24-2012, 11:29 PM
Did you figure it out??
post #12 of 19 (permalink) Old 02-25-2012, 12:56 AM
cummins24vturbodiesel's Avatar
iTrader Score: 6 reviews
With my quad on lvl 3, I could get 36-37 lbs of the hx35. On 5, it would hit 40-42. I was goofing around one day with the chip on 7, and I punched the fuel to look up at the boost and it was pretty near 50. I havent ran my chip over 5 since.
'99 2500 ,QCLB, 2.5" s400, ppump.
cummins24vturbodiesel is offline
