2001 dodge ram 2500 47RE tranny life - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-23-2012, 12:59 AM Thread Starter
Lcplneubecker's Avatar
Hey guys thinking about buying a 2001 dodge ram 2500 with the 24 valve and a 47RE AUTO TRANNY. It has 220k on it. Just wondering if they were driven "normal" and has done regular maintenance, how long do they usually last? The owner says it shifts strong. It's never been replaced
Sent from my Autoguide iPhone app
Lcplneubecker is offline
post #2 of 12 (permalink) Old 01-23-2012, 01:48 AM
i would probably count on replacing it soon.
DannyMK2 is offline
post #3 of 12 (permalink) Old 01-23-2012, 04:06 AM Thread Starter
Ok. The truck is stock also.
post #4 of 12 (permalink) Old 01-23-2012, 10:49 PM
kgirot58's Avatar
I have that exact truck, but mine has some minor power mods. Tranny was solid right up until it died suddenly at 203k miles. Lots of metal in the pan. It's a daily driver, no hot rodding, light/infrequent towing. $3500 to rebuild with a triple disc RevMax TC. I can't tell you if yours is about to go, but based on my experience, I would factor a rebuild into the price. I also don't recommend a triple disc unless you do major hauling. My new tranny shifts hard.
2001 Dodge Ram 2500 4x4, Quad Cab Long Bed, 47RE Automatic rebuilt with RevMax triple disc TC low stall, Edge EZ, Bosch RV 275 Injectors, FASS 95/95, AFE Stage 1 Intake w/Proguard 7, 4" exhaust turbo back, 210k miles.
kgirot58 is offline
post #5 of 12 (permalink) Old 01-24-2012, 08:09 PM
The Nut Puncher's Avatar
I bought mine with about 215k on it. I now have almost 245k. The trans shifts great. I wouldn't hesitate to take it on a long trip. I never floor it though. I dropped the pan, and it was clean. I put in a larger pan with cooling tubes, and I monitor trans temp with a gauge.
It's always risky buying a high mileage vehicle. I would budget a new or used trans into the equation. If it lasts, great. If not, you were kind of expecting it anyway.
The Nut Puncher is offline
post #6 of 12 (permalink) Old 01-24-2012, 08:21 PM
kgirot58's Avatar
IMHO, definitely do NOT get a used tranny unless you absolutely know it's history. These trucks are meant for pulling and you usually have no idea what you're getting. When my stock one died, I bought a used tranny ($1150 shipped) and paid $750 to have it swapped out. It was bad. Several trips to the tranny shop, two to the dealer, $400 replacing various sensors that might be the problem (they weren't) and I still had a bad tranny. Then paid another $150 to have it shipped back (got a refund) and had my stock tranny rebuilt. I wound up paying $1300 more than if I had just rebuilt mine to begin with. For the money I have in it, I could have had a complete Suncoast tranny. Lesson learned...
kgirot58 is offline
post #7 of 12 (permalink) Old 01-24-2012, 08:36 PM
I wouldn't put a used one in unless I got a great deal locally with a 30 day warranty (i.e. local u-pull it junkyard) and I was doing the labor myself. If I weren't mechanically inclined I would definitely get a rebuilt one instead. I was merely stating that a diesel truck with 200k on it has a lot of life left. People just assume anything with over 100k on it has one foot in the grave. Thanks for clarifying though kgirot58.
I swapped in a used 4L80E in a Trans Am a few years ago. It only had 10k miles on it, and I put in an upgraded TC and a shift kit. It saved me a lot of money and put up with the abuse of a bolt on LS1 easily. A little off topic though.
post #8 of 12 (permalink) Old 01-24-2012, 10:33 PM Thread Starter
Thanks for the replies gents. I forgot to mention the truck has never had a 5th wheel goose neck installed in the bed so I don't think the owner has towed very heavy loads with it.
post #9 of 12 (permalink) Old 01-24-2012, 11:20 PM
I know mine towed horse trailers for part of it's life. I don't know if the trans is original though.
post #10 of 12 (permalink) Old 01-25-2012, 03:25 AM
Coalroalinranchhand's Avatar
Mine has never been serviced in it life and I have 187,000 miles on it.
And it's never had a goose neck r 5thwheel but at 155,000 it started getting the power adders it has now.
99 2500 4wd. Qclb, fass150,S&B intake dry filter, 4 inch tbe mbrp, infinite performance 7X0.010's,isspro ev2 Trans,boost,egt,fuel preasure gauges, toyo mt 295/70/17, stage 1 firepunk trans,t3 steed manifold,arp 425 studs,beans fuel sump,pac brake bags,dana80 srw disk swap, edge ez,
Coalroalinranchhand is offline
post #11 of 12 (permalink) Old 01-25-2012, 04:00 AM
I bought mine 18 months ago at 230k, with the original transmission. Haven't bothered to drop the pan, or check anything. I fully expected it to die very soon. Clock now reads 268k... I tow a lot, and drive it with the hammer down. Transmission feels the same as it did when I purchased. It's become a bet now, how long will it last??? Time is the only way to find out.
In my opinion, and automatic transmission that makes it past 250k has certainly fulfilled it's service life, regardless of make and use. So if you're at 200k, I'd put it into the "budget" for replacement. And make sure you have a reputable vendor here do the work (goerend, dtt, suncoast, etc). It'll cost you a bit more upfront, but you wont' have to worry about it again.
2001, QCSB, 4" MBRP, 51" Donaldson, Edge Comp, FASS 3rd gen brakes, 3rd gen steering, Borgeson box & shaft & pump, superpro bushings, Blue Chip VP44 (awesome), Revmax fully built transmission (horrid experience)
ncsucarjock88 is offline
post #12 of 12 (permalink) Old 01-25-2012, 09:36 AM
bigdodge25's Avatar
Mines got 224k on it and I got it at 170k. Im guessing it’s the original tranny. It started messin up the other day but other than the one time its been good. Running an adrenaline too. I am changing the fluid, filter, and governor solenoid and pressure sensor Saturday so well see how bad it really is. Hopefully it lasts a lot longer though.
Soon to be For sale...2001 auto, 225k+, 6" lift, 5" stacks, k&n CAI, hx35, kumho AT 355/65 on 18's, raptor 150, Isspro EV2 FP gauge
bigdodge25 is offline
