p1690 code please help me out asap - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 01-02-2012, 08:21 PM Thread Starter
01 cummins buddy's Avatar
i have a brand new injector pump and brand new lift pump on my 2001 dodge 2500 cummins 6 speed ho i am throwing the p1690 rough idle within the first 5 to 10 mins of when the truck is first started then rough idle goes away also brings up check engine light and my headlights surge help me please i have been told it could be my cam shaft position sensor
01 cummins buddy is offline
post #2 of 16 (permalink) Old 01-02-2012, 08:43 PM
Ops
Ops's Avatar
Codes? Can't diagnose anything without it..
Ops
01 QC, totaled.
Early 04, 6 speed, power everything. Stock. so far.
Ops is offline
post #3 of 16 (permalink) Old 01-02-2012, 08:47 PM Thread Starter
code is p1690 i have a brand new injector pump and brand new lift pump need help wat the code is so i can fix it asap rough idle check engine light and surging headlights the rough idle is only within the first 5 to 10mins of start up then goes away i been told it could be my cam shaft position sensor
post #4 of 16 (permalink) Old 01-02-2012, 08:58 PM
alrhoads's Avatar
How many posts are you going to have on this?
1690, VP-44 and CKP sensors do not agree.
2001 F250 12V cummins (in progress) auto quad cab, AD2 150, 4K governer springs, HX35, Waste gate locked, TCU stand alone tranny controller, 9'6" v-plow, salt spreader.
alrhoads is offline
post #5 of 16 (permalink) Old 01-02-2012, 09:04 PM Thread Starter
does that mean my brand new vp could be bad just have a bad sensor what should i do to fix the problem or what would fix the problem
post #6 of 16 (permalink) Old 01-02-2012, 09:11 PM
alrhoads's Avatar
I would start with the sensor, you can get one at your local auto parts store.
alrhoads is offline
post #7 of 16 (permalink) Old 01-02-2012, 09:16 PM Thread Starter
so i should just start by getting and trying a new cam shaft position sensor.
post #8 of 16 (permalink) Old 01-02-2012, 09:20 PM
alrhoads's Avatar
I would test first before spending money. Moparman has a great write up on this. Or you could just go get the crank pos sensor.
alrhoads is offline
post #9 of 16 (permalink) Old 01-02-2012, 11:00 PM
RFDengine2's Avatar
Does sound like a bad cam sensor. Does your tach quit working? This would be a sure sign of bad cps. Headlights surging because of grid heaters cycling when first started.
01 3500 4x4 dually QC nv4500 w/ BD shortshift, Airdog II 165, Autometer guages, AFE cold air, stainless 4", Bluechip VP, CPP 125 inj, edge comp.
12 2500 4x4 CCSB auto, 20x9 moto metal +18, 305/55 nitto's
RFDengine2 is offline
post #10 of 16 (permalink) Old 01-03-2012, 12:25 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Here some this to help ya...
Mopar1973Man's Dodge Cummins Articles - P1690 VP44 CKP Sensor Does Not Agree With ECM CKP Sensor
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
post #11 of 16 (permalink) Old 01-03-2012, 01:19 AM
Cummins Fanatic/INJECTION PUMP TECH ADVISOR
Freeride202's Avatar
You might want to recheck the installation of the injection pump. Ensure that the key was aligned properly and not damaged. Also that the injection pump key was not installed backwards (arrow should point towards the pump).
Freeride202 is offline
post #12 of 16 (permalink) Old 04-30-2012, 02:33 PM
My truck is throwing the same code and my tack quit working... What is cps?
1999 24V Cummins
CollegeGirl is offline
