cummins grid heater problem - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 12-17-2011, 10:38 AM Thread Starter
i have a 98.5 cummins 24 valve that the grid heater will only work when i unhook the battery cables and put them back on then it will work for about 20 starts then do it all over. I also notice the lift pump dosent run for 3 sec or 25 when you bump the key. Im leaning torwards a bad ground or bad ECU.
Any suggestions guys??
honda80r is offline
post #2 of 9 (permalink) Old 12-17-2011, 10:45 AM
dodgecumminsfan:)'s Avatar
check for codes with the key trick and report back what they are if you have any.
2001 5 speed, AEM air intake, silencer ring mia, Airdog 100, Isspro boost, pyro, & fuel pressure gauges, 4'' turbo back to 7'' tip, 40% over vp44 built by Columbus Diesel, DDP 150's, Quadzilla Adrenaline
dodgecumminsfan:) is offline
post #3 of 9 (permalink) Old 12-17-2011, 11:40 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Won't work... 98.5 and 99 will not report error codes with the key trick...
Get OBDII reader pull the codes and report back...
Quit unhooking the batteries all you doing is wiping out the APPS calibration...
Mopar1973Man is offline
post #4 of 9 (permalink) Old 12-17-2011, 12:15 PM
KATOOM's Avatar
Ram Diesel Manifold Heater Problems
KATOOM is offline
post #5 of 9 (permalink) Old 12-17-2011, 12:22 PM
Twistedcummins's Avatar
Mine does something similar with the lift pump not running when you bump the key, but my grid heater only works sometimes. I got a P0606 code which is a bad ECM. So check codes
99 QCSB 4x4 auto/Edge/Airdog/Isspro
Originally Posted by USARMY12V View Post
With a 47RE it's impossible to tell. It's easier diagnosing what's wrong with a woman.
Twistedcummins is offline
post #6 of 9 (permalink) Old 12-17-2011, 01:22 PM
VP Moderator
dozer12216's Avatar
It might be good to check electical connections. The battery cables, The gray connectors near pass side negative cable, PCM ground strap, ground behind starter, grounds at both fenders, and make sure both batteries are good.
dozer12216 is offline
post #7 of 9 (permalink) Old 12-18-2011, 02:38 PM Thread Starter
i pulled codes with the scan tool and i got p0382-glow plug circuit B i also pulled ABS codes not sure if there related but they were Code 43,45 Open ECU Output and Code 65 Open Power Relay Contacts. I cleared all codes and my grid heater and lift pump stopped running.
honda80r is offline
post #8 of 9 (permalink) Old 12-18-2011, 07:21 PM
Mopar1973Man.Com
Here is the P0382...
Mopar1973Man's Dodge Cummins Articles - P0382 Intake Air Heater Relay #2 Control Circuit
post #9 of 9 (permalink) Old 12-19-2011, 09:35 AM Thread Starter
thanks this is what i needed
honda80r is offline
