Oil sending unit - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 12-15-2011, 05:41 PM Thread Starter
Oil sending unit
I posted on here about my oil sending unit being bad havent drove the truck any since it started messing up my truck has good oil pressure on a mechanical gauge so i was wondering if it was ok to drive it ive got to pull some stuff this weekend and my truck shut down or something because of that sensor . Really dont know alot about this i know when a powerjoke thinks its got low oil pressure it will shut down i just want to make sure mine want. Any info will be appreciated thanks.
elisdad21 is offline
post #2 of 5 (permalink) Old 12-15-2011, 05:44 PM
VP Moderator
dozer12216's Avatar
to my knowledge lack of oil pressure does not shut this engine down.
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
elisdad21 (12-15-2011)
post #3 of 5 (permalink) Old 12-15-2011, 11:35 PM
SD396's Avatar
Nope, won't shut down. Mines been running for over a month and a half with a bad sender with no problems, only the check guages light is on. I installed a mechanical oil pressure guage just to be sure I had pressure.
2001.5 Sport 4x4 QCSB, Auto, 5" stainless exhaust.116,000km garage queen.
2001 HO 6spd QCSB SLT Laramie 4x4, ---SOLD---
SD396 is offline
The Following User Says Thank You to SD396 For This Useful Post:
elisdad21 (12-16-2011)
post #4 of 5 (permalink) Old 12-16-2011, 12:28 AM
Jdufff25's Avatar
The 6.0 and 7.3 liter power strokes shut down when they have low oil pressure because their injectors rely on a high pressure oil system that is fed by the low pressure system to fire the injectors
Sent from my Autoguide iPhone app
2001 Ram 2500 4x4 24v Cummins 6spd
4in. Turbo back exhaust, 95gph fass platinum, RV275 injectors, S&B Cold air intake, 550hrs. South Bend Single Plate Clutch, Much More to come
Jdufff25 is offline
post #5 of 5 (permalink) Old 12-16-2011, 12:31 AM
Jdufff25's Avatar
There is no low oil shutdown on the cummins to my knowledge and I wrench on ford diesels they don't have one either. Little side note the power stroke heui injection system on the 6.0 and 7.3l engines wasn't designed by ford or intertrashional it was designed by caterpillar and if they would leave it alone it's extremely reliable
Jdufff25 is offline
