Fuel in Oil Pan - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 12-11-2011, 11:58 AM Thread Starter
Crewcabchevy's Avatar
iTrader Score: -1 reviews
Fuel in Oil Pan
Truck starts up rough, and has a slight knock, getting fuel in the oil pan, and builds up pressure in fuel tank, and white smoke from the exhaust, any ideas?
1998.5 Cummins 24 valve, Airdog 150, super b special turbo, 12 mm head studs, .093 cross over tubes, Hot Rod VP pump, DDP 150 sticks, nv4500, i think thats about it.
Crewcabchevy is offline
post #2 of 8 (permalink) Old 12-11-2011, 12:16 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Blowing compression into the fuel tank could be...
  • Cracked head
  • Bad copper shim on the injector
Fuel in the oil could be...
  • Bad front seal on the VP44
  • bad injector leaking fuel
Time to do a compression test.
Mopar1973Man's Dodge Cummins Articles - Compression Testing
This will tell you if the head is cracked...
Then I would have the injectors pop tested. This will rule out a leaking injector.
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
post #3 of 8 (permalink) Old 12-11-2011, 02:40 PM
VP Moderator
dozer12216's Avatar
Could be a loose injector leaking both ways. What have you done recentlly, before this malady started??
dozer12216 is offline
post #4 of 8 (permalink) Old 12-11-2011, 03:02 PM Thread Starter
I rebuilt the motor about 6 months ago, and everything has been running fine, I just replaced the transmission about 2 months ago, the head thats on it is brand new, so i don't think thats the problem, i retorqued the head about 2 months ago.. thats it though..
post #5 of 8 (permalink) Old 12-11-2011, 03:38 PM
VP Moderator
dozer12216's Avatar
since it can't be the engine messed up internally by your diagnois, it must be the headlight switch routing current into fuel tank causing fuel to swuirt into pan after the tank is reverse pressurized. HeHe.
post #6 of 8 (permalink) Old 12-11-2011, 05:26 PM
Mopar1973Man.Com
I'm stumped then...
post #7 of 8 (permalink) Old 12-11-2011, 05:36 PM
dodgecumminsfan:)'s Avatar
It could be a cracked injector body.
2001 5 speed, AEM air intake, silencer ring mia, Airdog 100, Isspro boost, pyro, & fuel pressure gauges, 4'' turbo back to 7'' tip, 40% over vp44 built by Columbus Diesel, DDP 150's, Quadzilla Adrenaline
dodgecumminsfan:) is offline
post #8 of 8 (permalink) Old 12-14-2011, 07:03 PM Thread Starter
Im going with it being an injector, thanks guys!!
