nv4500 disassembly - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 11-05-2011, 07:30 PM Thread Starter
Double-O-C's Avatar
nv4500 disassembly
hey guys, im putting a new clutch in this week, and also getting my case welded due to a little crack. but besides that, should i remove the shifter cap and top cover and re seal to ensure that when i put the tranny back in the truck that all the leaks stop?
ive never disassembled a nv4500 before so my next and most important question for you guys is, when i remove the top cover (not just the shifter cover) ARE THERE GONNA BE ANY PARTS THAT COME FLYING OUT? or is it simply just a cap??
thanks
'00-QCSB-5 speed-BHAF-silencer ring MIA-4inch downpipe-fbd 5"-Raptor 150-20%-bombproof rockers-tow mirrors-hbs 2"-3rd gen track bar-rocksolidram-borgeson box-fixin ram seals-315/75/16-26 led's-jl audio-adrenaline iquad-sbdd3250
Double-O-C is offline
post #2 of 7 (permalink) Old 11-05-2011, 08:13 PM
Shockwave's Avatar
Nope, no parts will fly out. The cover is sealed with silicone.
I've rebuilt mine with the Quad4x4 kit and I'm installing the big input shaft this weekend...
I bent the friction disk installing it last time so be careful removing and installing the trans. Or you'll have shifting problems with a slightly bent disk.
Good Luck.
2001 3500 DRW, Quadcab,NV-4500 with Torque King main shaft and 1 3/8 input shaft(after broken mainshaft and 5th gear failure), Edge juice with Attitude,4in exhaust,100hp Injectors.
Shockwave is offline
The Following User Says Thank You to Shockwave For This Useful Post:
Double-O-C (11-05-2011)
post #3 of 7 (permalink) Old 11-05-2011, 08:26 PM Thread Starter
Double-O-C's Avatar
ill be extra careful, im gonna reseal the shifter cover AND the main cover just to make sure i dont have any leaks from there, my transmission is soaked so i wont know where the leak is coming from until i pull the tranny, as long as the main cover doesnt have any parts to fly out with it then what kind of silicon sealant should i use??
thanks
matt
post #4 of 7 (permalink) Old 11-05-2011, 09:00 PM
Shockwave's Avatar
I'd be willing to bet that you shifter seal is leaking. It's the seal under the 4 bolts that have to be removed to remove the lower shifter rod.
I's say it would be unusual for silicone to just fail on the top between the case and aluminum cover.
Need a technical manual shoot me an email.
Steve8511@gmail.com
post #5 of 7 (permalink) Old 11-05-2011, 09:06 PM Thread Starter
Double-O-C's Avatar
ok thanks! i got a leaky transfer case, cracked bellhousing so ill be in touch, ill be tearin everything apart in a few days
post #6 of 7 (permalink) Old 11-06-2011, 02:09 AM
rhagfo's Avatar
Good Luck.
Best bet is to use a transmission jack, NV4500 is heavy, transmission jack makes it easy to line up.
Once you have the transmission within 3/4" of the bell housing, you are just short of getting the shaft into the pilot bearing. At this point I either have a helper depress the clutch, or use a board to hold it down.
This allows the friction disk to float free while getting the shaft into the pilot bearing. This is done by HAND, you should be able to get the surfaces of the Bell Housing and transmission flat together without using the bolts, otherwise you may bend things.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 296K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
The Following User Says Thank You to rhagfo For This Useful Post:
Double-O-C (11-06-2011)
post #7 of 7 (permalink) Old 11-08-2011, 03:43 AM
cummins_sn0rt's Avatar
use anerobic sealer not silicone you will be much happier
cummins_sn0rt is offline
The Following User Says Thank You to cummins_sn0rt For This Useful Post:
Double-O-C (11-08-2011)
