oil level - Dodge Cummins Diesel Forum
Old 10-09-2011, 06:34 PM   #1 (permalink)
gasmask1942's Avatar
oil level
feel like an idiot asking this, but id rather be safe then sorry on this.
i checked my oil level this morning. on the first pull ( truck sat on level ground all night 15 hours ) it was just into the add section of the dip stick. put it back in to double check and it came out a little over the add into the safe. checked it a third time and it was reading it was completely full. so my question is whats my actual oil level
2001 2500 Ext cab long bed Sport with, BHAF, raptor 100, boost egt fp gauges,smarty, 5" stacks, turbo ate silencer ring
gasmask1942 is offline   Reply With Quote
Old 10-09-2011, 06:40 PM   #2 (permalink)
Clunk's Avatar
Every time you draw it out, it brings some of that oil up into the dipstick tube, then that gets on the dipstick on the next draw..
Your 1st draw was a good one. imo
'01.5, QC, SB, 6spd, 4x4, Comp, 4" exh., C300 Cat turbo w/adj.boost elbow, Big Line, fuel press.,pyro & boost gauges, cheapo fuel cooler, BHAF, IP 200 nozzles, single Holley style pump/13psi WOT, Ceramic/Kevlar SD clutch
Clunk is offline   Reply With Quote
Old 10-09-2011, 06:48 PM   #3 (permalink)
rhagfo's Avatar
I always check oil after the truck has been sitting at least an hour, I also check sitting in the same place. First draw is the most accurate. Before you pull the stick, make sure it is seated all the into the tube.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 258K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 16 PSI, 3.55's, Kool Vue Tow mirrors, Pacbrake, Puke bottle deleted.
rhagfo is offline   Reply With Quote
Old 10-09-2011, 07:40 PM   #4 (permalink)
VP Moderator
dozer12216's Avatar
Dipstick training suggested.
Make sure stick is fully seated each time. And does not move on clamp.
2008 3500 stock QCLB dually Inferno red. Toys of all sizes:Fuel injected Rampage, Grader, 1586 tractor, 60K genset, Honda Foreman ATV, and more. Back in business with a Hitachi EX270LC excavator. The dirt slinging has begun with 50+ acres to clear.
dozer12216 is offline   Reply With Quote
Old 10-09-2011, 08:02 PM   #5 (permalink)
i have it seated the best i can get it, my mechanic broke the top of it off where it says engine oil when he replaced the lift pump. he ordered me a new one but it wouldnt go in all the way. we figured cause it was straight and didnt have the spirals in it like the one that is in there now. so im waiting on another one to come in. =/
Old 10-09-2011, 08:37 PM   #6 (permalink)
rhagfo's Avatar
Geno's has one that is a bargain.
CUMMINS ENGINE OIL DIPSTICK ('01-'02, 24V)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Local Cummins dealer may have one also.
