How to tell if truck has the 53 block - Dodge Cummins Diesel Forum
 1Likes
post #1 of 45 (permalink) Old 09-11-2011, 05:24 PM Thread Starter
As the title states, how do I know if the truck has a 53 or 55 block. Is there a way to tell in the vin? Or do you have to get under truck to look. I'm looking at an 2002, did they come in that model year? please help
2001 Ram 2500 CUMMINS QCSB 4WD SLT LARAMIE with 6" Fabtech Lift, 35 Mud BFG Terrain Tires wrapped around 17" American Racing Rims, Edge EZ Chip, 155 HP Injectors, AirRaid Cold Air Intake, Banks Ram Intake, 4 inch exhaust with 5 inch tip
NateJoppeck112 is offline
post #2 of 45 (permalink) Old 09-11-2011, 06:04 PM
So the question is???
9612vinva's Avatar
there will be a 53 under the PS/VP area...
97 ECLB Manual...2ndGenDoms trucks EVIL TWIN
Originally Posted by v8440 View Post
There's a guy floating around here with 780k on his unrebuilt cummins. Now, according to duramax and ford guys, his truck should have fallen completely apart around the engine 7.8 times, since they all know that dodge trucks are junk and only last 100k before they spontaneously disassemble themselves while going down the road. That has happened to me 2.76 times, and both times I was only wearing boxers while driving so it was really embarrassing.
9612vinva is offline
post #3 of 45 (permalink) Old 09-11-2011, 07:14 PM
As stated above. The letters are about 1" tall and are below the injection pump, just above where the oil pan bolts to the block. The numbers are not hard to see or find.
If memory serves me, I think the 53's were used before 2002, (2001 and older) but someone that knows better may correct me. I have an 02 and it is a 56.
02 2500, QCSB, CTD, Auto, 4.10 gears, Patriot Blue/Silver, New VP44 and lift pump in 2008 at 42K miles. 56K as of 8/11 No performance mods, puke can is gone, and vent tube mod., Air Dog 100, Draw Straw V, 1/2" Vulcan Big line. Gauges, steering stab. bar, brite box
RJC2 is offline
post #4 of 45 (permalink) Old 09-11-2011, 07:18 PM
upinsmoke53020's Avatar
Only 98-00 have 53 blocks
99 Dodge Ram 2500, 5-speed, Edge Hot Juice w/attitude, RV275's, 4" turbo back exhaust, BHAF, Pro Comp M/T 33X12.50R17, Leveled, AIRDOG 150, Boost, Pyro pillar guages.
upinsmoke53020 is offline
post #5 of 45 (permalink) Old 09-13-2011, 12:17 PM
JohnVH's Avatar
and for the record not all 98-00 have them in there.
'05 QCSB 4x4 2500, 5.9, 6 speed, SouthBend SDD3250-GK clutch kit, Edge Evo CTS, K&N, level kit
JohnVH is offline
post #6 of 45 (permalink) Old 09-13-2011, 01:11 PM
Driver side front of engine block. Very front corner, on the side, just above the oil pan rail.
You'll find a big "53", "55", "56", or....no big numbers at all.
Note: there's a wiring harness right in the way down there though. Has a loom bolted there also. You may have to unbold that loom and move the harness to be able to see it.
Very RARELY do you see a "53" casting in an 01 or 02. I've seen a few, but, cannot confirm who put them there. (dodge or prev owner)
IMO: I wouldn't worry about what's in it now. I'd worry about what numbers are on the replacement block when/if the time came.
Redlinear is offline
post #7 of 45 (permalink) Old 09-13-2011, 04:51 PM
R.D.J.'s Avatar
Mines got a 53 and its a 2001. Only 68,000 KILOMETERS on it though, and it was in there since new. Im keeping my fingers crossed.
2001 QCSB 4X4 Laramie, full billet built (by me) Gorend 47RE, BHAF, 5" MBRP, Edge J/A, and Smarty, 75HP DDP injectors, Stainless diesel 62/65/14, 315/75R16 Toyo M/T, Carli starter kit with Bilstein 5100's, Line X rockers, Coolant and Interior Webastos.
R.D.J. is offline
post #8 of 45 (permalink) Old 09-13-2011, 05:39 PM
cummminsV12's Avatar
1103Dp Cummins Fatal Flaws Engine On Stand Photo 3
53 Block FAQ and Information
The way I did to chek mine is go to driver side under the truck and look near the oil pan with a good led light. Took me 5 minutes to find 54B and not 53
01 ECSB SPORT-Quad4K,DTT Built47re/48RE inside,AD2-165,RADbox,PusherIntake,7x.012w/lift,Silver64,ARPStuds
cummminsV12 is offline
post #9 of 45 (permalink) Old 09-13-2011, 09:09 PM
dragpipe's Avatar
what if you have no numbers at all
03' qclb 4x4 5spd 250hp 3.73 gears bone stock.....for now
SOLD !! 98.5 quad cab,4x4,auto,b.h.a.f,silencer ring m.i.a,5" straight piped,adrenaline with a pulse v2,air dog 100 w/ 1/2" lines
dragpipe is offline
post #10 of 45 (permalink) Old 09-14-2011, 09:51 AM
That's a good thing.
post #11 of 45 (permalink) Old 09-14-2011, 10:21 AM
Take a look just under the vacuum pump on the side of the block, you'll see it. Imagine my joy when I found this
'99 Ram 2500, 24V CTD, 2WD, 202K, 53 block (yay), S&B filter, Edge Comp box, RV275s, FASS DDRP, 5" straight pipe.
'06 Charger R/T, Hemi, 42K, stock
Mike99CTD is offline
post #12 of 45 (permalink) Old 09-14-2011, 12:55 PM
There is always a number on there...You just didnt find it.
