crank position sensor - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 09-11-2011, 01:18 PM Thread Starter
Hello all !! a little update from my last visit on the forum. I have been seeking info on my 2001 cummins and thank you to mopar1973man for his insight and upon suggestion went back to dodge and asked if they could reflash my ecm because they cannot seem to find the proble as to why my truck has the fault code 0336 which is the crank position sensor and the 01 does not apparently have this sensor but has a cam position sensor that had been married to the crank sensor. still with no answers as to the fault codes being read then and very frustrated with Dodge for yankin everyones chain over this !! has anyone ever experianced this carnage of a merry go round. I appreciate any feed back to shed light on this
Thank you
62cowboy is offline
post #2 of 7 (permalink) Old 09-11-2011, 03:08 PM
Clunk's Avatar
Check behind the starter on the side of the engine block. The parts books show a crank position sensor for a 2001 but I've read it's only there for factory assembly. I got under the truck and checked my '01.5 & it's just a tabbed hole.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #3 of 7 (permalink) Old 09-11-2011, 06:12 PM Thread Starter
Thanks Clunk but my truck does not have the crank sensor there either !! the cummins dealer said Dodge moved it and changed the name of it to an engine speed sensor but thats not it either speed sensor is for the trans and front and rear diffs
62cowboy is offline
The Following User Says Thank You to 62cowboy For This Useful Post:
Jmfunder1 (09-13-2011)
post #4 of 7 (permalink) Old 09-12-2011, 09:44 PM
Clunk's Avatar
Did you actually see the P0336 ?
You might try going to a chain type auto parts store and ask for a free diagnostic scan.
Clunk is offline
post #5 of 7 (permalink) Old 09-12-2011, 11:15 PM Thread Starter
thanx Clunk yes I get the code on my hypertech and also seen the code when dodge scanned my truck and they had no explanation other then new ecm !! so if they say my truck does not have a crank sensor ! Why ? do I get the code?? Dodge wont give a straight answer and its frustrating!!!
62cowboy is offline
post #6 of 7 (permalink) Old 09-12-2011, 11:27 PM
Clunk's Avatar
They just don't know.
Looks like maybe if your PCM/ECM was from another year or truck, it would show up in the identification or maybe it'll identify with your vin, regardless, I agree on your re-flash idea so it'll "think" like a 2001.5.
Clunk is offline
post #7 of 7 (permalink) Old 09-12-2011, 11:34 PM Thread Starter
you would think then they could reflash my ecm but they said no gotta buy a new one for $1700.00 but Dagger Diesel performance says no bring it to us !! so thats my next move and will see if I get it staight up and will let the forum know in the next few days! thanx clunk
62cowboy is offline
