Oil leak! - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 09-03-2011, 06:12 PM Thread Starter
BiGn'NASTY's Avatar
Exclamation Oil leak!
Hi all, I'm hoping to get some insight on what's leaking oil on my 02 5.9, so here goes.
It started as a slow leak but has now turned into a BAD leak It's now a constant drip off the bottom of the IP and only leaks with the engine running. I've been reading a lot of threads about oil leaks from the same area and most people are finding that it's the tappet cover leaking. I can see the tappet cover and the oil is NOT coming from there, it's up higher.. Thanx in advance for any insight or advice!
Jay
02 2500 4x4 QCSB 66mm polished/stainless High Tech Turbo, Blue Chip VP44, Blue Chip FMS+Redline boxxes, I.I. 150s, FASS150, ARP studs, O-ringed head, dual solenoid NX, 5" stainless slash-cut Silverlines, BUILT 47RE and more
BiGn'NASTY is offline
post #2 of 12 (permalink) Old 09-03-2011, 06:13 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
The only thing I can think of higher is head gasket...
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
post #3 of 12 (permalink) Old 09-03-2011, 06:25 PM
dodgediesel59's Avatar
Have you physically seen it dripping off the injection pump or just from down below in that area? A very common and severe leak can develop from between the vac pump and the power steering pump and be very hard to find
Robert
2001 2500 flat bed with dual 5" stacks, billet auto,P-pump, 191's, 4gsk, 0 plate garrett 3788R colt stage 2 cam, .084 lines 125 vp injectors at 280 bar
dodgediesel59 is offline
post #4 of 12 (permalink) Old 09-03-2011, 06:29 PM Thread Starter
BiGn'NASTY's Avatar
Yes, I'm actually watching it drip off the IP. I'm thinkin maybe the o-ring where the IP goes into the timing cover, but it seems like pressurized oil and the timing case isn't under oil pressure... I really hope it's not the head gasket.
post #5 of 12 (permalink) Old 09-03-2011, 06:37 PM
That o ring wouldnt be much of a leak in my mind, its a pretty tight fit in the timing case anyways and not alot of oil is flung up there. Tappet cover has no pressure either anywhere. can you geta little dentists mirror and a light up top to try and see it?
Robert
post #6 of 12 (permalink) Old 09-03-2011, 06:42 PM
So the question is???
9612vinva's Avatar
Cam sensor???
97 ECLB Manual...2ndGenDoms trucks EVIL TWIN
Originally Posted by v8440 View Post
There's a guy floating around here with 780k on his unrebuilt cummins. Now, according to duramax and ford guys, his truck should have fallen completely apart around the engine 7.8 times, since they all know that dodge trucks are junk and only last 100k before they spontaneously disassemble themselves while going down the road. That has happened to me 2.76 times, and both times I was only wearing boxers while driving so it was really embarrassing.
9612vinva is offline
post #7 of 12 (permalink) Old 09-03-2011, 06:48 PM Thread Starter
BiGn'NASTY's Avatar
Yeah, that's how I saw the oil dripping off the IP is with a little mirror and a light. My father has got an inspection camera and I'm gonna look at it with that before i start tearing it apart.. Still anymore ideas or info is welcome!! And thanx again for info thus far.
post #8 of 12 (permalink) Old 09-03-2011, 07:18 PM Thread Starter
BiGn'NASTY's Avatar
Originally Posted by 9612vinva View Post
Cam sensor???
Is the cam sensor up higher than the IP??
post #9 of 12 (permalink) Old 09-03-2011, 07:24 PM
Branden246's Avatar
It's actually right beside the vp on the block. If you look behind the vp with a light you might be able to see it. I replaced mine when I put my injection pump on because it's much easier to get to with the pump off.
2001 3500 SRW 12mm Ppump 651/1158 @ 40 psi, 24*
SO VP Fuel Only 606/1138
Branden246 is offline
post #10 of 12 (permalink) Old 09-03-2011, 07:30 PM
9612vinva's Avatar
could be the oil fitting for the vac pump...
post #11 of 12 (permalink) Old 09-03-2011, 08:26 PM Thread Starter
BiGn'NASTY's Avatar
Good news! Just started to tear into it and further inspect and found that the stud closest to the block for the IP is MIA. Started it up and watched the hole and that's where the leak is. Now i just gotta fannagle my way in there with an extention and throw a bolt in the hole and I should be back in business
post #12 of 12 (permalink) Old 09-03-2011, 09:15 PM
markkerkof's Avatar
Time to buy a lotto ticket. Whodathunk a mounting bolt hole would go all the way
through? Have to put that tidbit on the hard drive.
2001.5 Quad 4x4 5.9 24V Air Dog, Pyro,Tran,EGT, Boost Isspro. BHAF,4"TB,Super B,DynomiteDiesel 75s
markkerkof is offline
