Loss Of boost/power code p0237 p1693 - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 08-25-2011, 07:02 PM Thread Starter
Confederate Cummins's Avatar
02 2500 six speed, through codes p0237 and p1693, first one is turbo/super boost sercuit A low pressure. next one says it is a companion coad. When it first threw the code no loss of power or boost just the engine light, scanded the light cod the above codes. cleared codes drove fine for a day. then loss of power and boost, but no engine code. the power and boost loss is intermintent. been doing some studying up on this issue, and have heard that it could be a faulty MAP sensor, or my chip could be causing the issue.
2002 2500 six speed
(afe intake, 4 inch turbo back exhaust to staight pipe, FASS hpfp, pack brake, booste, fuel pressure, and exhast temp guages, and a Speed three stage Chip.
Confederate Cummins is offline
post #2 of 5 (permalink) Old 08-25-2011, 07:08 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
Does your chip plug into the MAP sensor connection? If it does, yeah thats possible, if it doesn't its definitely a bad MAP sensor.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #3 of 5 (permalink) Old 08-25-2011, 07:08 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Unplug the chip and test again... The boost fooler could be screwed up...
P0237 - Map Sensor Voltage Too Low
MAP sensor voltage input below the minimum acceptable voltage.
Monitor & Set Conditions
Manifold Air Pressure (MAP) sensor voltage is monitored when engine is running. DTC may be stored if
Engine Control Module (ECM) senses low MAP sensor signal voltage.
Possible Causes
  • Other DTCs
  • Boost Pressure Sensor
  • 5-volt Supply Circuit
  • MAP Signal Circuit Short To Ground
  • MAP Signal Circuit Short To Sensor Ground
  • MAP Sensor
  • Intermittent Wiring Problem
  • ECM
Testing
1. Turn ignition on with engine off. Using DRBIII(R) scan tool, check for engine DTCs. If any 5-volt supply
circuit DTC(s) exist, perform appropriate test. See DIAGNOSTIC TROUBLE CODE DEFINITIONS .
If no 5-volt supply circuit DTC(s) exist, go to next step.
2. Start engine and allow engine to idle. Using scan tool, read MAP sensor voltage. If MAP sensor voltage
is .2 volt or greater, go to next step. If MAP sensor voltage is less than .2 volt, go to step 4 .
3. Shut engine off. Turn ignition on with engine off. Using scan tool, read MAP sensor voltage. If MAP
sensor voltage is less than 2.35 volts, go to next step. If MAP sensor voltage is 2.35 volts or greater, go to
step 9 .
4. Turn ignition off. Perform turbocharger boost pressure test. See TURBOCHARGER under AIR
INDUCTION SYSTEMS in SYSTEM & COMPONENT TESTING - RAM PICKUP - DIESEL article.
If boost pressure test passes, go to next step. If boost pressure test does not pass, repair as necessary.
5. Ensure ignition is off. Disconnect MAP sensor harness connector. MAP sensor is located on driver's side
rear corner of cylinder head. Turn ignition on with engine off. Using DVOM, measure voltage at terminal
No. 1 (Orange wire) on MAP sensor harness connector. If voltage is 4.7-5.3 volts, go to next step. If
voltage is not 4.7-5.3 volts, repair Orange wire between ECM and MAP sensor. ECM is located on
driver's side of engine, just in front of fuel transfer pump and contains a 50-pin connector.
6. Turn ignition off. Ensure MAP sensor harness connector is still disconnected. Disconnect ECM harness
connector. ECM is located on driver's side of engine, just in front of fuel transfer pump and contains a 50-
pin connector. Using DVOM, measure resistance between ground and terminal No. 2 (Gray/Red wire) on
MAP sensor harness connector. If resistance is 1000 ohms or greater, go to next step. If resistance is less
than 1000 ohms, repair short to ground in Gray/Red wire between MAP sensor and ECM.
7. Using DVOM, measure resistance between terminal No. 3 (Black/Light Blue wire) and terminal No. 2
(Gray/Red wire) on MAP sensor harness connector. If resistance is 1000 ohms or greater, go to next step.
If resistance is less than 1000 ohms, repair short between Black/Light Blue wire and Gray/Red wire.
8. Turn ignition off. Reconnect ECM harness connector. Using scan tool, read MAP sensor voltage. If MAP
sensor voltage is greater than 4.5 volts, replace and program the ECM. See appropriate REMOVAL,
OVERHAUL & INSTALLATION article. If MAP sensor voltage is 4.5 volts or less, replace MAP
sensor. See appropriate REMOVAL, OVERHAUL & INSTALLATION article.
9. Turn ignition off. Visually inspect related wiring harness. and connectors between MAP sensor and ECM.
Look for any chafed, pierced, pinched or partially broken wires. Visually inspect MAP sensor harness
connector and ECM harness connector for broken, bent, pushed out or corroded terminals. Check for any
Technical Service Bulletins (TSB) that may apply. Perform a wiggle test on the related wiring harnesses
with the ignition on, engine not running. Repair as necessary. If no problem is found, test is complete.
Mopar1973Man is offline
post #4 of 5 (permalink) Old 08-25-2011, 09:03 PM Thread Starter
map sensor unpluged
I unpluged the wires coming from my chip that looked to wired into the map sensor and, and made sure my chaarge piping was good and tight with no leaks, no boost loss or power loss. test drove it my chip still made my rig have more power just blue black quite a bit more and made it idle a little wierd, sounded like it was gargaling when I had the chip still on, never threw a code though
post #5 of 5 (permalink) Old 08-25-2011, 11:43 PM
Mopar1973Man.Com
You suppose to remove the chip completely and hook up the MAP sensor again. Just like it was factory...
