How well is YOUR fuel filtered? - Dodge Cummins Diesel Forum
Old 12-02-2005, 07:30 PM   #1 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
Do YOU have any of this stuff flowing in YOUR fuel lines?
http://www.turbodieselregister.com/f...549post1368549
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline
Old 12-03-2005, 05:13 AM   #2 (permalink)
Guest
Guest
Posts: n/a
Not that good thats for sure !!!
DM
Old 12-03-2005, 09:07 AM   #3 (permalink)
Super Moderator
Another good reason to drive a 12 valve where the lift pumps don't disintegrate.
illflem is offline
Old 12-03-2005, 12:01 PM   #4 (permalink)
Tech Specialist
Well, there ARE trade-offs - the 24 valvers are capable of on-the-fly timing and fueling changes, delivering both economy AND power on instant demand the earlier purely mechanical fuel systems can only DREAM of...
As to the above threat, THAT is easily cured by any of several replacement LP setups available that remove the drive motor from the fuel stream.
Is the use of the 24 valve style LP a significant reason to avoid that engine?
Not for me.
Would I STILL use that Frantz fuel filter even in a 12 valve fuel system as protection against all OTHER potential fuel contaminents and impurities?
YOU BETCHA!
Old 12-04-2005, 12:30 PM   #5 (permalink)
Tech Specialist
"If heat is such a concern with the VP44 then why is the ECM on the motor with less concerns? Check the temp of the VP44 and the ECM after a hard long run. Can you slow it down from failing?"
WHY is my Cummins equipped 2500 more powerful in towing than a Hemi equipped one?
Apples/Oranges you will say - different units in different uses...
Same goes for the comparison between electronics inside a VP-44, and those in the ECM - they are made by different manufacturers to different tolerances, perform different functions, and mounted in different locations - even so, the ECMs DO fail!
The vast majority of discussions in forums like these are about "overkill" - how much power do you REALLY need? How big an exhaust - how much bigger injectors? How fast in the quarter mile, or how far in a sledpull do you really NEED to go?
Why is "overkill" in filtration to EXTEND the life of an engine and it's components any greater an evil or less desireable than POWER mods to SHORTEN it's lifespan?
Discussions in forums like these have the basic purpose and advantage of providing readers with OPTIONS - some options are based upon increased reliability - some for more power.
Who's to say THEIR mods or upgrades are more appropriate or important than someone elses?
Old 12-04-2005, 01:13 PM   #6 (permalink)
Guest
Guest
Posts: n/a
Originally Posted by Gary - K7GLD
SOMEHOW, I suspect ONE of us won't last long on this board without a substantial attitude adjustment...
now now fellas................YES some folks like to take things to extreams , some with HP/TRQ and some with preventative methods, Both you guys have valid points here but I just like to see all options out there so a feller can choose his options as they are available, we have a feller at work that is our lube oil specialist and this guy likes to change the oil on his truck every 2k miles..............is this an extream....YES, is it valid...........In his mind it is so in the end we just let him do what ever he wants.
Life is GOOD
Old 12-04-2005, 02:35 PM   #7 (permalink)
YOU JUST DON'T GET IT!!!
pro99's Avatar
I removed the post myself,
If that was intended to publicly belittle or needle me personally, it accomplished it's goal!
It's nothing like that at all!!
Thank Chaz!
pm or call BBRam or Wally at FTE Diesel for all of your Michigan's Best parts, pricing and service!!!
pro99 is offline
Old 12-04-2005, 02:39 PM   #8 (permalink)
Guest
Guest
Posts: n/a
Chaz, I thought you had some goood points in that post?
Old 12-04-2005, 02:40 PM   #9 (permalink)
Guest
Guest
Posts: n/a
Be Cool Guys Valid points from both parties. How about an agreement to disagree. Please try not to egg each other on .
DM
Old 12-04-2005, 02:45 PM   #10 (permalink)
pro99's Avatar
Thanks Whitmore!
pro99 is offline
Old 12-04-2005, 03:03 PM   #11 (permalink)
Guest
Guest
Posts: n/a
OK so since this horse has been beat to death lets all move on now.........thanks men
Old 12-04-2005, 03:08 PM   #12 (permalink)
pro99's Avatar
Where did you find that at? Now that is funny
pro99 is offline
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
