Drop Tank or Lift Bed? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 07-18-2011, 11:41 AM Thread Starter
Hey All-
I am needing to check to see if I am getting air in the fuel from the drawstraw or lines previous to the Rapor - Seem like we are getting air into the system.
What is easier, dropping the tank (1/4 full) or lifting the bed?
Thanks!
'01 3500 Club Cab Dually 4x, 6 speed manual. 24v 5.9, Banks system,high Ram intake, Otto Computer, big head turbo wastegate, Turbo,Pyro, fuel pressure Gauges, Monster 4" Banks Exhaust w/ Exhaust Brake, Raptor 150, Draw staw and big lines to VP. Level kit.
Zcarbri is offline
post #2 of 13 (permalink) Old 07-18-2011, 03:23 PM
PatD's Avatar
I had a fuel pick-up problem in the spring and raised the bed to fix it. Drop the spare remove the 8 bolts a gnd strap and unplug your tail lts. You'll need atleast 1 assiatant 2 would be better. I raised the bed slid it back and supported it w/jackstands on the frame. Its not any easier than dropping the tank but I liked working on it that way you could see everything w/out slicing your head open
99 2500 5 spd 275 hp injectors, afe stage ll, van aaken sb-r, 4" str8 exhaust, fass 150, pyro, boost, fuel press, LUK cerametallic, boost elbow,tunnel ram
PatD is offline
post #3 of 13 (permalink) Old 07-18-2011, 03:23 PM
Well....
I dont know how to drop the tank, but I have swapped beds... Its not that tough, but the SOB is freakin heavy...
The bed is held on the truck with 8 bolts through the bottom.. Just lay on the ground and look up..4 each side.. one will be by the trailer hitch in the frame rail, the next one is a few feet forward, then the remaining two are in front of the wheel on the outside of the frame rail.
Remove the tailights and drop the harness down through the metal work, and disconnect the two plugs on the drivers side near the frame rail in the back and the marker light harness comes off with the bed.
Remove the fuel door, then the 3 screws that hold the filler neck to the fender.. Remove the hose clamps from the filler tube for the tank and remove.
Have about two freinds minimum ready to help you lift the bed out of the way.
Y'all say 'redneck' like its a bad thing
1999 3500 4wd auto ext cab- JUNKYARD FREE SPIN CONVERSION
NO MORE UNIT BEARINGS
1997 F350 crew 7.3 Powerstroke- modded
BoostedOne is offline
post #4 of 13 (permalink) Old 07-18-2011, 08:03 PM
gqrealtor's Avatar
When I did my raptor and drawstraw, I unbolted the bed and then used two floor jacks and blocks and lifted the front corners of the bed enough to get in there and work. It was easy and quick, just lowered the jacks back down and bolted bed back down, did it without any extra help
1999 QC 2wd LB, Raptor 100, Drawstraw I,1/2" big line kit, FP Guage, BHAF, 1.5" leveling kit, 4" TBE, I Quad Adrenaline, 2 stroke oil,transgo shift kit, boost elbow
gqrealtor is offline
post #5 of 13 (permalink) Old 07-18-2011, 08:53 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Mine was really easy... I got a bunch of beer, a friend, and place a beer in one hand and a camera in the other and documented how it was done... I didn't have to do a thing...
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For This Useful Post:
gqrealtor (07-18-2011)
post #6 of 13 (permalink) Old 07-19-2011, 05:48 AM
2500ctd's Avatar
When is your friend's days off and what beer does he drink?
RIP: '01 2500 QCSB Goerends, triple disc, walbro 392HTT-62/65/12, CPP 7x10 SAC's
05 2500 CTD 4x4 6spd QCLB
2500ctd is offline
post #7 of 13 (permalink) Old 07-19-2011, 06:27 AM
Texas 24 valve's Avatar
Yup thats what happened to me, the tank fell on me and i cut my finger and messed up my thumb. The 2nd time was much better, two people and a floor jack acting like the third. On my truck a 2wd short bed i had to drop a cross member to fit the tank out but it wasnt to hard.
1998.5 QCSB 2wd 5speed Sold at 115k
2015 Tradesman CCSB 4x4 auto
USMC Infantry
Texas 24 valve is offline
post #8 of 13 (permalink) Old 07-19-2011, 09:16 AM
Mopar1973Man.Com
That tank was empty... Even drink beer we were smart enough to pump the fuel into 5 gallon buckets.
post #9 of 13 (permalink) Old 07-19-2011, 09:56 AM
VP Moderator
dozer12216's Avatar
My gooseneck hitch is bolted to frame and bed. Removal is very difficult, so droped tank. When dropping tank, be carefull and don't destroy fuel line connections or damage fuel module... removing or tilting bed up would be a better option if possible.
dozer12216 is offline
post #10 of 13 (permalink) Old 07-19-2011, 10:04 AM
Mopar1973Man.Com
Way to get around that problem is simple. Loosen the collar nut on the sender and allow the sender to come up and out of the tank as the tank is lowered to the floor. Once the tank is on the floor then you can remove the sender from the tank gently and the work with ease to remove the fuel lines from the sender.
post #11 of 13 (permalink) Old 07-19-2011, 10:10 AM
2500ctd's Avatar
Next time I am going to try to tilt the bed. Broke one bolt off and then a drill bit off in that bolt Only thing is I have a topper.
2500ctd is offline
post #12 of 13 (permalink) Old 07-19-2011, 08:23 PM
I dropped the tank. It was easy. Before unbolting it I built something really easy to build and simple. It was essentially a wide ladder, that I chained to a branch in a tree. It was about 12 feet long, and I had it in the tree chained about 3 feet from the truck. I slid the ladder under the truck, and had my fiance' sit on the end sticking out. That raised the part under the truck to the tank, and I unbolted the tank, it sat on the ladder and she got off it slowly lowering it to the ground.
Then you can just swing it out. Oh the truck is up on blocks to get some height under it.
Chris
5.8LiterImportEater is offline
