codes: P1693 and P done - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 07-17-2011, 05:10 PM Thread Starter
OK so ive been reading for a couple hours strait now and Im starting to go nuts. I know this has been done before and im sorry but im still new to cummins and a rookie when it comes to all these things.so the problem.... Going around 100 km/h or 60mph i get a loss of power slighty for around 2 seconds and then its gone. This comes and goes around every 10-15 mins, This just started happening to me on the way home from a trip. I filled my gas up at a hilibily station were i was and wondered if i got bad fuel???
As for the codes that came up i got p1693 and then p DONE that was all? should i try reseting my apps? Any help would be great.
2001 ex cab SB 6 speed, 4x4. 4" magnaflow TBE, AFE intake, 75hp injectors, BD lift pump, 33" goodyear wranglers.
welli is offline
post #2 of 12 (permalink) Old 07-17-2011, 07:14 PM
There are supposed to be other codes as indicated by the 1693. What scanner did you use?
Regarding Apps reset, see mopar1973man's site for his comments and method.
2000 LWB, Quad Cab, 4x4, NV4500, AirDog, Gauges, Thuren Track Bar, Lost crappy AGR and A1-Cardone steering boxes. RedHead is the best so far but truck has stopped returning to center. Hopefully, I'll get to it soon.
Junkman is offline
post #3 of 12 (permalink) Old 07-17-2011, 07:57 PM
If you're using the key trick to pull the code and you have a 2001 (not 2001.5) you'll never get the second code. You'll need to go to an auto parts store that can read the code for you.
I'm sure you saw the sticky (number 3 or 4 from the top of the page) about the P1693 being a companion code.
Scott91370 is offline
post #4 of 12 (permalink) Old 07-17-2011, 07:59 PM
I think he did the key trick. Make sure wait to after the first set of codes. It will tell you the ecm codes, flash p-done 3 times and then tell you the codes on the pcm.
SledTurd18 is offline
post #5 of 12 (permalink) Old 07-17-2011, 08:13 PM Thread Starter
yes i did the ket trick. sledturd18 it doesnt give me a second code. it just goes back to my milage??? and yes my truck is not a 2001.5. So i guess its off to the shop to get it read then.
welli is offline
post #6 of 12 (permalink) Old 07-17-2011, 10:58 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
2001 are known for this issue...
Question what color is your odometer display orange or green?
Mopar1973Man is offline
post #7 of 12 (permalink) Old 07-18-2011, 02:22 AM
jason's Avatar
Mine does the exact same thing but no code . Been like this for awhile and no fix for it yet . I was hoping a new TIMBO APPS would be a good start
2000,4x4, quad, 285 Disc. AT's, XZT+ to big hoss level 5,banks high ram,banks wastegate,100hp injectors,4"tbe,TAG,ranch hand,leveling kit,triple disc TC, Transgo Tugger VB, trans,pyro,boost,fuel press gauges, BHAF, FASS 150 Titanium
jason is offline
post #8 of 12 (permalink) Old 07-18-2011, 05:39 PM Thread Starter
odometer display is green
welli is offline
post #9 of 12 (permalink) Old 07-18-2011, 06:15 PM
fhlh's Avatar
An Autozone or any reputable parts store can read the code for you.
Write them down and come back here and let us know!
2000 2500 QCLB 6sp 4x4 Camper Package | 4" MBRP | BHAF | Boost Elbow | TS MVP-SmartySO3 | ISSPRO-EGT-FP-BOOST | FASS Titanium 150 | SSIM DSS | New VP44@145k | Gen 3 Brakes | Various Dents
2013 BMW 335i M-Sport 8spA
2011 M-B GLK350
fhlh is offline
post #10 of 12 (permalink) Old 07-18-2011, 06:25 PM
Mopar1973Man.Com
I'm trying to figure out if the color of display has a reason to it. Kind of a mixed bag what I'm finding.
He's got that right on... Report back with the codes...
post #11 of 12 (permalink) Old 07-19-2011, 08:16 PM Thread Starter
ok so took it to my buddies shop today..... the same code P1693 came up as well as codeP0382 (intake air heater relay #2 contral) as well as P 0602 (ECM fueling calibration error) So we tested it and found out that the intake air heater was had come unplugged. We plugged it back in and it tested properly. On my was out the door right now to take it for a burn on the the highway to see if shes all fixed.
welli is offline
post #12 of 12 (permalink) Old 07-19-2011, 08:59 PM
My 2001.5 gave me a 1693 then a 216 so what does that mean for me?
2004.5 3500 drw crew cab, lwb, 4x4, 48re, Fass 95, smarty jr, 3.73lsd, K2 21 ft toy hauler
Gerry Roach is offline
