Auto to manual swap. 2nd gen 2wd - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 07-17-2011, 04:00 PM Thread Starter
Hey guys I was going to go crazy and put a 10 SPD fuller in my truck till a guy bought it off me to put in his 5.9l 12v power military deuce and half. So I'm now looking at a g56 or going with a ford ZF6 heard the ZF is stronger. Well all in all what am I looking at other then the trans, flywheel, and clutch. Do I need complete manual pedals or just a small brake pedal, and the parts for the clutch pedal, I got a new master cylinder I'm sure I can make work if I use a ZF trans. Can some one help with a list of what to due to swap out the 47RE to a manual. Thanks guys I need to start looking at buying parts soon I want to do this swap over the winter.
2001 Ram3500, 47RE ext cab dually 2wd,
2005 Ram3500 thunder road, 48RE quad cab dually.
speedy81304 is offline
post #2 of 4 (permalink) Old 07-17-2011, 09:28 PM
duernkyl2's Avatar
i am currently in the middle of my swap...best thing is to find a donor truck...you will pay way to much if you go individual parts....mine is a 2000 2wd also...the only thing i have left is the drive shaft...the donor truck had a splt shaft with a bearing in the middle....and well its to short and the bearing holder dont line up....so now thats what im trouble shooting...otherwise it would be on the road!
2000 2wd. LIFTED ON 315's. 4inch Turbo Back. Smarty. Edge Hot. Fass 150. 220000 miles on origional vp
duernkyl2 is offline
post #3 of 4 (permalink) Old 07-18-2011, 01:28 AM Thread Starter
Donor truck is a no go, if I found one it would coast to much, as around here people don't like to give up any dodge diesel truck parts with out asking for a ton of money, so I'm hitting up the wrecking yards for some of the needed parts, I can have a drive shaft made up no problem. What's all needed in the cab, do I need a complete pedal assembly or do I just find a smaller brake pedal and add in the clutch assembly.
post #4 of 4 (permalink) Old 07-18-2011, 11:15 PM Thread Starter
Ok how strong is the nv4500 I see 14500 gvw. But what about hauling could it hold up to daily abuse of up to 26,000 lbs. I found s good used nv4500 for a couple hundred bucks.
