Adjusting Valves on 24 Valve - Dodge Cummins Diesel Forum
post #1 of 32 (permalink) Old 06-03-2011, 05:37 PM Thread Starter
Tejas TJ's Avatar
I'm going to adjust my valves in the morning. I read that setting TDC can be done by the altenator nut. To me with all the compression on these trucks that doesn't seem possible. Can anyone confirm this is a good way to do this?
2001.5 CTD
Tejas TJ is offline
post #2 of 32 (permalink) Old 06-03-2011, 09:01 PM
PatD's Avatar
I did mine yesterday, use a 15mm 1/2 in dr socket and turn the alternator counter clockwise it is not that hard to turn.
99 2500 5 spd 275 hp injectors, afe stage ll, van aaken sb-r, 4" str8 exhaust, fass 150, pyro, boost, fuel press, LUK cerametallic, boost elbow,tunnel ram
PatD is offline
post #3 of 32 (permalink) Old 06-03-2011, 09:04 PM
All-in99's Avatar
I couldn't turn my alternator nut and turn motor at same time I had to do it off crank took me about an hour an a half easy to do truck runs alot better also a good oppurtunity to paint valve cover to lol but it's an easy job just remember .010 on intake and .020 on exhaust on a cold motor I did the go no go method to be sure
99 eclb 3500 ...gone
01 qcsb 2wd 5 spd, edge drag comp, DAP 175's, isspro gauges str8 pipe and running a lil bit toasty more to come...
All-in99 is offline
post #4 of 32 (permalink) Old 06-03-2011, 09:05 PM
EJS0806's Avatar
Yeah thats how you do it.. Some guy has a website and he has AMAZING step by step tutorials of this.. Im sorry but got a new computer and now dont have it in my favorites.. I cant remember but pretty sure someone will jump in and tell you it hes also a member on here. Also im going to be doing mine here pretty soon.. Did you have to replace the valve cover gasket or can you reuse them??
12 2500 laramie 4X4 nv5600 S475 fleece coolant bypass 125 injectors steed speed manifold h11s Hamilton 110s 12mm stroker cp3 airdog150 w/sump Southbend 3250 grid heater delete/gdp intake turbo smart bov thuren/carli
EJS0806 is offline
post #5 of 32 (permalink) Old 06-03-2011, 09:06 PM
All-in99's Avatar
You can reuse it just clean it and the mating surfaces
All-in99 is offline
post #6 of 32 (permalink) Old 06-03-2011, 09:10 PM
EJS0806's Avatar
ok sweet thanks im probably going to do mine this weekend then i bought my truck with 190K on it and ive had it for like 5K and im not sure if it was ever done at the recomended 150K so better be safe then sorry.. How do you tell intake from exhaust valves?? is it just basically commene sense whats the cover is off??
EJS0806 is offline
post #7 of 32 (permalink) Old 06-03-2011, 09:14 PM
PatD's Avatar
moparman1973 has a step by step
PatD is offline
post #8 of 32 (permalink) Old 06-03-2011, 09:15 PM
All-in99's Avatar
Intake is closer to the intake side an has smaller rockers exhaust has larger rockers,I did mine two weeks ago truck runs quieter and smoother when you check the clearance check it between the bridge and the spacer it's really easy cyl 5 and 6 are tougher but it's worth it my truck had 190000 when I did em the other day
All-in99 is offline
post #9 of 32 (permalink) Old 06-03-2011, 09:21 PM
Clunk's Avatar
Here it is, good stuff,
2nd Generation Dodge Cummins - Valve Lash Adjustment
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
The Following 2 Users Say Thank You to Clunk For This Useful Post:
DodgeMech (06-03-2011), PatD (06-03-2011)
post #10 of 32 (permalink) Old 06-03-2011, 10:13 PM
Hemi
iTrader Score: 5 reviews
Set them to 8 and 18.
Just a troll nowadays
mjd91 is offline
The Following User Says Thank You to mjd91 For This Useful Post:
gqrealtor (06-04-2011)
post #11 of 32 (permalink) Old 06-03-2011, 10:36 PM Thread Starter
Tejas TJ's Avatar
8 and 18 are for a warm motor correct?
2001.5 CTD
Tejas TJ is offline
post #12 of 32 (permalink) Old 06-03-2011, 10:56 PM
dodgeram18's Avatar
mjd91 why .008 and .018? i set mine to .015 and .025 it spooled my single charger quicker than my older setting but now my twins seem weak, i just figured i need more fuel and porting.
12 HO 3500 Laramie CCSB 68RFE 4:10 4x4 H&S mm, FP5" tbe, S&B cai
SOLD: 02 2500 47RE MBRP 4" STR8 pipe, Afe, S357/S475, ATS 3-piece, ARP, FASS 95/150, DDP 110s, Edge Juice + HOT, NADP full race
68 GMC (under const) lwb2swb, 2wd, 47re, 24valve, ppump, big sticks, big single batmowheel, 4/6 drop, 22s, 67 clip and box sides
I need more parts
dodgeram18 is offline
