Lift pump for 99 dodge - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 05-19-2011, 11:30 PM Thread Starter
I know this topic has been talked about many times,but I'm still stuck. I have a ram 3500 flatbed with 410 gears and are looking to put some pep into it while maybe gaining a little mpg. I've looked into all the top rated lift pumps on this site and have found just as many horror stories as blessings. So what do I do? I'm not a pedal on the floor type of guy, really just looking to get a good performing diesel without shortening the life of the motor. The stacks are already installed and the intake is coming. I've read when adding a programmer it's wise to upgrade the lift pump. I've already replaced one lift pump luckily before the injector pump failed, so I'm try to avoid the dreaded injector pump death. Need your guidance>>>>>>>>>>>>>>>>>>>>
trich27 is offline
post #2 of 18 (permalink) Old 05-19-2011, 11:38 PM
Raptor 100, I love mine and I've never heard a bad word spoken about them.
2000 3/4 4x4 CCLB Auto. 203k, Dipricol FP gauge, 2 stroke lubin'er up, Raptor 100, "Swiss Cheese" air box suckin' wind, Power Puck.. .. Parts fixed - Vac. pump sealed, new rad., BD APPS noise filter, puke bottle gone.. So far, so good!
rockyraider is offline
post #3 of 18 (permalink) Old 05-20-2011, 03:52 AM
rockrash's Avatar
Relocate the lift pump to the frame rail just in front of your fuel tank. With a vulcan kit this will eliminate the banjo fittings. The pump will last longer since it is now pushing the fuel further than it has to draw it from the tank....and it no longer has to tolerate engine heat and vibration.
My parts store Airtex replacement pump runs 15+ lbs. at highway speed (my gauge only reads 16 lbs. and usually stays pegged). 14 lbs on long hills, and 9-10 psi WOT loaded. This is with a diablo power puck.
This same pump when mounted on the block would pull down to 4-5 psi WOT loaded. This relocation and increase in pressure/flow shows how hard the LP has to work to pull fuel from the engine compartment mounting location and the restriction of the banjo bolts.
When I first relocated my airtex pump I still had the banjo bolt on the output and it would pull down to 7 psi. I gained 2-3 psi by simply replacing the banjo bolt (which is 5/16") with the Adapter from Vulcan for the airtex pump converting to a JIC fitting with a 3/8" barb fittiing.
the factory line from the tank is a 3/8" feeding the pump, but it is a 5/16" between the pump and the filter housing through the quick connects and banjo bolts.
I see my advantage over the Raptor, air dog, fass, etc. on only a slightly modified truck in the fact that if it dies on the road I don't have to spend the night in the Bates motel while i wait on fedex to ship me a new pump. Every parts store in town carries the improved design Airtex fuel pumps.
02 2500, auto,4" turbo back,puck,Gauges....... E7153 Airtex LP because I refuse to conform...201k+ and counting on original trans.
. It runs on oil so it tows stuff good.
rockrash is offline
The Following User Says Thank You to rockrash For This Useful Post:
RFRam (05-20-2011)
post #4 of 18 (permalink) Old 05-20-2011, 05:10 PM
Mutch79's Avatar
I second the relocation kit!!! Done my self also when I still had my stock pump. It made the stock pump last twice as long as normal (which was still just a couple of months). Since I've gotten the DDRP hooked there, we are good to go!!!
P.S. I never subscribe, so pm if you have follow up Q's
07 2500 SLT-Long Bed, 5.9L H.O., 2WD, 2.5" level kit, Diablo Sport Programmer, Cat Delete, Magnaflo Muffler, K&N Cold Intake, ALLISON T-1000 Conversion, Stage 2 TQ, Ford 6.0 Starter, 256:1 2-Stroke Mix, functional hood intake. Leather seats from an 09.
Mutch79 is offline
post #5 of 18 (permalink) Old 05-20-2011, 06:38 PM
So what do I do?
Opinions are like elbows. You've read the posts so pick a pump. There's nothing new under the sun - especially regarding lift pumps on 10+ yr old trucks.
2000 LWB, Quad Cab, 4x4, NV4500, AirDog, Gauges, Thuren Track Bar, Lost crappy AGR and A1-Cardone steering boxes. RedHead is the best so far but truck has stopped returning to center. Hopefully, I'll get to it soon.
Junkman is offline
post #6 of 18 (permalink) Old 05-20-2011, 09:55 PM
Kamikazekyle05's Avatar
Raptor 100
1999, single cab, 4x4, 3500, Edge Comp, RSD 5" TBE, 5 speed, whistler air intake, 4.10's, Thuren track bar, Big Line Kit, Raptor 100, Isspro EV2 FP, Boost & EGT Gauge, PSC Steering Brace, Sport Headlight Conversion, Bilstein Shocks & Steering damper
Kamikazekyle05 is offline
post #7 of 18 (permalink) Old 05-20-2011, 11:12 PM
sledwrecker's Avatar
Raptor or FASS, spend a little more now, save a lot (of money and headaches) later. The relocation is just a band aid IMHO.
00 SWB, Quad, Auto, 2wd, BHAF, FASS 95, Juice WAM, 4" Diamond Eye Strait,Smarty,3cyl/hi idle box.
98 RC 3500 4x4, 12 valve,DDP 75's,4k gsk,ARP studs,NV4500 with South bend 1 3/8" input shaft and OFE Con single disk,flatbed. 4" Diamond Eye Strait,BHAF.
sledwrecker is offline
post #8 of 18 (permalink) Old 05-21-2011, 09:15 PM
rhagfo's Avatar
This is a pick your poison question, yes you will find a lot of threads at this LP or that LP has failed. They are mechanical devices, that is why no matter what you have for a Lift Pump you have a good Fuel Pressure gauge, so you know what your fuel system is doing.
My next step is to relocate my FASS DDRP-02 back to the fuel tank. Replaced it out side this winter in about 35 degree weather at night, didn't want to do the relocate right then.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 296K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #9 of 18 (permalink) Old 05-22-2011, 04:07 AM
SpaceHiker's Avatar
I tried the relocation with the stock pump and that was a waste of time and money, 1 year later I was back to square one. I've had my Raptor 100 for 3 years now and haven't had the slightest problem, fuel pressure stays exactly where it's supposed to.
1998.5 24v 5spd 4x4 ClubCab. BHAF. 4" Banks Brake/Power Elbow/Monster exhaust. Raptor 100. Frantz filter. Westach gauges. Cooper ATP 265/70/17 on 4th-gen Laramie alloys. RedHead steering/Borgeson shaft/DSS. Rancho 9000. MaxxLinks. Rustoleum paint. 275k miles.
SpaceHiker is offline
post #10 of 18 (permalink) Old 05-22-2011, 04:40 AM
Honestly even with a stock truck the dodge lift pump is not up to the task at hand. You need a good fuel pressure gauge and a good aftermarket pump. The best bang for the buck is the raptor 100. They will give you room to grow (up to about 400hp) and are a very strong little pump. I see other guys recommending a relocation kit and the fass ddrp. I am not trying to argue with anyone or hurt anyones feelings, but both are just a waste of money compared to the raptor. I dont know the cost of the relocation kit, but its not going to be a cost effective option in the long run. The fass ddrp pump is a complete waste of money imo. I think they go for somewhere around 300 bucks. For an extra 75 bucks you can get the raptor which is 5 times the pump and plus have all 1/2 inch fuel lines as well. If you read and search the site for a few minutes you will see people having nothing but problems with either of those options. Now yes I know this might just be my opinion, but 9 out of 10 people will agree with me on this one. Im just trying to save you your time, money, and the headache of doing and paying for all of this stuff twice. Keep in mind though that if you have the dealer installed in tank lift pump then you are going to have to install a drawstraw 5 with the raptor, but honestly it isnt that hard of a job. The drawstraw costs about 45 dollars extra and make your system a full 1/2. If you still have the block mounted lift pump then all you have to do with the raptor 100 is hook it right up to the stock fuel pickup. Any questions just ask bud we are all here to help. And since your going with a good reliable pump once the performance bug hits you, which it will if you so much as a power puck, then you have room to grow. These trucks really wake up and go with just a simple extra 50 hp.
2002 QCSB 6 Speed/ Quad Adrenaline 4k With PV2
/ Raptor 150/ Big Line Kit/ BHAF/ 4 Inch MBRP/ 285 75 Nitto Terra Grapplers
curtis026 is offline
The Following User Says Thank You to curtis026 For This Useful Post:
sledwrecker (05-22-2011)
post #11 of 18 (permalink) Old 05-30-2011, 12:32 AM Thread Starter
Thanks for the help, do any of you have any input on a programmer for this truck. this is a working truck not a go fast blow black smoke truck. I've gone with hypertech in all of my other trucks but in this dodge I'm not sure if that's the best way to go. Just looking to get a little more pep out of my old truck. When you have a 40ft trailer loaded with hay it's nice to know if you want it you got it.
trich27 is offline
post #12 of 18 (permalink) Old 05-30-2011, 02:08 AM
rockrash's Avatar
Best bang for your buck in my opinion (less than $200) is a Diablo Power Puck.
50 hp, 150 tq. A literal 5 minute install if you stop to open a beer during the install. It puts the power right where you want it to maintain speed when towing. A nice seat of the pants gain. A puff of black when you mash on it, then clears right up.
I would recommend a pyro but I've never seen over 1200 with 23 lbs boost and a 4" pipe. But know this. It only takes a few seconds for EGT's to climb 600 degrees and drop just as fast when you let out of it. If you tow alot of hills it's a good idea to pony up and install one, pre turbo.
rockrash is offline
