01 crank sensor position - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-18-2011, 08:26 PM Thread Starter
cwarta's Avatar
were is the crank sensor located on a 01 ?
2003 6sp, custom intake horn, 4" mbrp, fass lp, trinity, Fs 2500, bd short shift, valair DD ceramic clutch, 4" lift, 33`s, 2 MIC filter system, Propane Injection
cwarta is offline
post #2 of 10 (permalink) Old 04-18-2011, 08:47 PM
Between the VP and the block.
2001 cummins automatic 2500 x-tended cab , airdog 150, edge juice/w/attitude , mbrp 4'' need more
to keep going
wontgoslo is offline
The Following User Says Thank You to wontgoslo For This Useful Post:
cwarta (04-18-2011)
post #3 of 10 (permalink) Old 04-18-2011, 08:52 PM
Clunk's Avatar
That's the camshaft position sensor. The '01 doesn't have a crankshaft position sensor.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
The Following User Says Thank You to Clunk For This Useful Post:
cwarta (04-18-2011)
post #4 of 10 (permalink) Old 04-18-2011, 09:16 PM Thread Starter
cwarta's Avatar
its my dads truck, and its gettin worse.... youll be cruizing along nd the cel will come on and tach drops to nothin, and absolutly no balls..... we were told the crank sensor was out and it was running on the cam sensor........? what you think
cwarta is offline
post #5 of 10 (permalink) Old 04-18-2011, 09:21 PM
98,99,00 had crank sensors 01,02 switched to cam sensors. Same sensor functions though.
to keep going
post #6 of 10 (permalink) Old 04-18-2011, 09:25 PM
I just went through these exact symptoms. Replaced the "camsaft position sensor" on my 01. Shes back to normal. Hope you have small hands, its tight back there.
to keep going
post #7 of 10 (permalink) Old 04-18-2011, 09:25 PM
Clunk's Avatar
Turn the keyswitch On-Off-On-Off-On then look at the odometer for a code.
Clunk is offline
post #8 of 10 (permalink) Old 04-19-2011, 03:05 AM
cybermavrik's Avatar
iTrader Score: -1 reviews
When installing a CPS use a 5 to 6 inch extension on the socket, i used a 1/4 drive, so your ratchet head has plenty of clearance and is functioning in the open just between the power steering resevoir and the fuel filter... and you wont have to jam your hand below the injector pump. Put a small piece of masking or duct tape across the opening of the socket, push the socket over the bolt and that way no worries about losing your bolt.
May you be born in interesting times- chinese proverb
2001 quad cab drw 4x4 auto tranny 218k no mods...bd performance noise filter, iss fuel pressure gauge, BHAF
cybermavrik is offline
The Following User Says Thank You to cybermavrik For This Useful Post:
Clunk (04-19-2011)
post #9 of 10 (permalink) Old 02-20-2012, 12:30 PM
My 2001 cummins is throwing the P0016 cank/cam code. Im going to change the sensor today and hopefully it helps.
When its below freezing it barely starts and blows white and has no power till it warms up. But if its plugged in or warm it starts easy and throws no codes. It was in a front end wreck befor I got it and I hope it isnt any of the keys that are off or that my pump might be failing?
Sorry for putting this here, Im new and cant for the life of me figure out how to post a question and thought this was closely realted enough here
My truck is stock except for an edge ez chip and 4inch straight pipe. I just had the ECM looked at and it was fine too.
6speedchick is offline
post #10 of 10 (permalink) Old 02-21-2012, 02:54 AM
Are all 2000's supposed to have ckp sensors? Mine does not nor does it have the wire to hook up too
99 eclb, 4x4, auto $SOLD
94 rc/flat bed, 4x4, auto $traded
00, 2500, 160k 01 engine 300k truck?, 2wd, 5spd, qclb, BHAF, pyro/boost gauges, XZT
darktwin1979 is offline
