Clutch will not disengage! - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 04-12-2011, 06:16 PM Thread Starter
lbdodge24v's Avatar
We finally got my transmission fixed, NV5600. Put the input shaft in and some of the bearings that had to be removed for the other repairs. After getting everything back together last night we took the truck off the lift, cranked it, and tried to put it in gear. It seems the clutch is not disengaging. The pedal pressure is about a quarter what it was before all this happened. We also put in new clutch disk and throw out bearing. The pressure plate moves a lil bit but not enough to disengage. Trying to figure out where to put my money on this, already got enough into the repairs and now need something else. . What are your thoughts, throw another upgrade hydraulic on and hope that fixes it or is there something else I should try first?
Thanks for any and all help on this.
02 Dodge CTD, 6 spd, Drag comp/Smarty, HMR DD, aFe, TUNNEL RAM, MBRP 4in, 3 gauges.
95 Dodge CTD, 3 gauges, trans by Prostreet Diesel and DPC
The Toy a Jummins!Sold!
lbdodge24v is offline
post #2 of 11 (permalink) Old 04-12-2011, 06:32 PM
KONG
1slo_CR's Avatar
iTrader Score: 6 reviews
Could the disk be in backwards?
-2014 Ram 2500 MegaCab LIMITED, White, 3:42`s.
RIP- '6.5 RC SRW, GORILLA56r, SBC3850, 3.42`s, Hellman, Full Port/Polish, Floor-It Stg3.5, '10 #s-12.543@111.51 838hp/1691tq FUEL ONLY on a STOCK INTAKE HORN
-'10 Impulse Nytro 174
-'14 MPI Viper 141
1slo_CR is offline
post #3 of 11 (permalink) Old 04-12-2011, 06:46 PM Thread Starter
lbdodge24v's Avatar
put them in per the labels on them. So shouldn't be unless they were mislabeled.
post #4 of 11 (permalink) Old 05-05-2011, 01:49 PM
02CarolinaCummins's Avatar
slave cylinder
02CarolinaCummins is offline
post #5 of 11 (permalink) Old 05-05-2011, 02:06 PM
BigCE's Avatar
Originally Posted by 02CarolinaCummins View Post
slave cylinder
2nd that, I just did mine would not disengage when cold. Was also slowly engaging on its own with clutch to the floor.
2010 2500 Mega Cab Laramie Sold
2015 Jetta TDI...Yep
BigCE is offline
post #6 of 11 (permalink) Old 05-05-2011, 02:39 PM
wait? u second me? i have to think this is what my old mud toy use to do so i replaced it and fixed my problem ive also put disc in backward on a jeep MISTAKE" and it wouldnt disengage llet us know what u find
2002, 2500, 63mm borgwarner, .093lines, .093tubes, DDP150hp, SB dual-disk, 1"fuel lines, Fass150, smarty programmed, cold air intake, 5" flo~pro exhaust sitting on 20"s wrapped in 35"s
post #7 of 11 (permalink) Old 05-05-2011, 02:52 PM
BigCE's Avatar
Sorry I just meant that was my opinion as well.
BigCE is offline
post #8 of 11 (permalink) Old 05-09-2011, 01:47 PM
ahhh its cool bro i gotcha
post #9 of 11 (permalink) Old 05-09-2011, 09:46 PM
STRAIGHT6BEAST's Avatar
Probably slave cylinder. Anyone press the clutch pedal while the slave was out of the bellhousing? It has air in the system now.
Colby
Another slow, ugly 2nd gen under construction
STRAIGHT6BEAST is offline
post #10 of 11 (permalink) Old 05-09-2011, 11:59 PM
jwalth02's Avatar
Them... is it a dual disc? Was it in before or is this a new dual disc upgrade from a single?
Here: 2013 CCLB 6spd manual stock truck.
Gone: '02 24 Valve 6spd Manual
jwalth02 is offline
post #11 of 11 (permalink) Old 05-11-2011, 12:55 AM Thread Starter
lbdodge24v's Avatar
Well turns out it wasn't the slave or master cylinders. Put a new HD set on, didn't really need them since the other HD set was still good. Turns out in our hurry, and lack of sleep in the middle of the night, we put the pressure plate on wrong, it was not on the marks. And the pressure plate needed shimmed. Now it works and truck is doing good for now.
