All symptoms point to cam sensor... right? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 03-30-2011, 08:14 AM Thread Starter
leman's Avatar
A few months ago i put a new injection pump in and while i had it out, i also put in a new CAM sensor in just for safe measure because it was easy to get to.
Recently, my RPM gauge has been not working once and a while along with the check engine light, and the truck acts very sluggish when it does stop working. From this i figured it must be a bad CAM sensor, so i put the old one back in because i know it was still good and should work. After a few days of driving, the check engine light came back on with the same symptoms as before.
Is there a possibility that something else is causing these problems, or am i just unlucky and both CAM sensors went bad at the same time? I dont know what the check engine light code is because i dont have a scanner and it is a 99 so i cant do the key trick. Any help would be appreciated, thanks
1999 dodge 2500, ext cab, short bed, 6spd std, SO, Air Dog 150, BHAF, silencer ring MIA, IQuad, More to come
"You hafta put the power making stuff in the power making place to make power"
leman is offline
post #2 of 6 (permalink) Old 03-30-2011, 10:07 AM
JonXR5's Avatar
It could be your crankshaft position sensor. It's behind the starter. Have it scanned to make sure.
Jon
'02 QCSB 4x4 auto, 4" turbo back exhaust, BHAF, BD Flow-Max LP, Edge JWA/CS
JonXR5 is offline
The Following User Says Thank You to JonXR5 For This Useful Post:
leman (03-31-2011)
post #3 of 6 (permalink) Old 03-30-2011, 10:40 AM
VP Moderator
dozer12216's Avatar
True, suspect the crank sensor and look carefully at wiring. Possiblly pinched during VP replace???
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
leman (03-31-2011)
post #4 of 6 (permalink) Old 03-30-2011, 02:22 PM Thread Starter
leman's Avatar
i never would have thought of it being the crank sensor. I quickly checked the wires for the CAM sensor when i changed it, but ill check again and try to find someone with a scanner. Thanks for your help
leman is offline
post #5 of 6 (permalink) Old 03-31-2011, 12:48 AM
sledwrecker's Avatar
The tach doesn't get it's signal from the cam sensor on your truck. It only does on the ones without a crank sensor. Hence the tone ring is on your crank. check your crank sensor.
00 SWB, Quad, Auto, 2wd, BHAF, FASS 95, Juice WAM, 4" Diamond Eye Strait,Smarty,3cyl/hi idle box.
98 RC 3500 4x4, 12 valve,DDP 75's,4k gsk,ARP studs,NV4500 with South bend 1 3/8" input shaft and OFE Con single disk,flatbed. 4" Diamond Eye Strait,BHAF.
sledwrecker is offline
The Following User Says Thank You to sledwrecker For This Useful Post:
leman (03-31-2011)
post #6 of 6 (permalink) Old 03-31-2011, 08:14 AM Thread Starter
leman's Avatar
I changed the crank sensor last night and it was a PITA. It took a few hours of fighting and making a special tool to pull it out, but it fixed the problem. I think i might invest in buying a code scanner for the future. Thanks again for everyone's help
leman is offline
