locker rear end, speed sensor won't work - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 03-23-2011, 01:46 AM Thread Starter
i just bought this truck the rear end has a locker in it, (hops and makes bunch of noise when turning) i pulled the cover and looked very new. my problem is the speedo doesn't work and putting a new speed sensor in there didn't help. do i need a special one or?... 99 dodge ram 3500 193k
bedrockmotors is offline
post #2 of 13 (permalink) Old 03-23-2011, 01:59 AM
jwalth02's Avatar
Did it have the tone ring on it? Looks like a gear with a LOT of teeth on the side that bolts to the ring gear.
Here: 2013 CCLB 6spd manual stock truck.
Gone: '02 24 Valve 6spd Manual
jwalth02 is offline
post #3 of 13 (permalink) Old 03-23-2011, 02:01 AM Thread Starter
the big gear yes
post #4 of 13 (permalink) Old 03-23-2011, 02:31 AM
jwalth02's Avatar
Just to be clear...
The tone ring to the left. I know it's not the same axle but same concept.
And have you tried grounding the plug and seeing if your speedo max's out? Plus with the key off, hold in the odometer reset button and turn the key on. Your dash should spaz out and start doing a diagnostic. If it goes through it's cycle and the gauge doesn't move with the rest you probably have a bad cluster.
jwalth02 is offline
post #5 of 13 (permalink) Old 03-23-2011, 03:13 AM
wiring well known to break just where the sensor wire goes into the main harness up on the frame, remove all the shielding and pull/tug the wires, dragging your thumbnail against the wire will help locate a break internally even if the outter sheath is intact
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #6 of 13 (permalink) Old 03-23-2011, 08:43 PM Thread Starter
Go figure there is no exciter/tone ring WTF
post #7 of 13 (permalink) Old 03-23-2011, 09:15 PM
jwalth02's Avatar
That could be why it's not working. I remember seeing them for sale somewhere but don't remember... Maybe a trip to the junk yard is in order.
jwalth02 is offline
post #8 of 13 (permalink) Old 03-23-2011, 09:20 PM Thread Starter
any ideas? from what alldata tells me speedo wont work because of that ring right?
post #9 of 13 (permalink) Old 03-23-2011, 09:20 PM
VP Moderator
dozer12216's Avatar
Man, that redneck mechanics who decided to save some weight was smart, wer'nt he...Ha Ha
Or more likely the locker was not machined for tone ring and he never gave it a thought. Guess what has to be done to fix.
dozer12216 is offline
post #10 of 13 (permalink) Old 03-23-2011, 09:22 PM Thread Starter
junk yards wont sell that, whole thing or nothing. are they difficult to put on?
post #11 of 13 (permalink) Old 03-23-2011, 09:48 PM Thread Starter
i prob have to get a whole new rear end?
post #12 of 13 (permalink) Old 03-23-2011, 10:37 PM
jwalth02's Avatar
Mine came off and went back on with a little tapping with a rubber mallet. But as dozer stated, if it doesn't have the machined lip for it you're kinda SOL. I don't know why it wouldn't have it though. Do you have a closer pic of the left side?
jwalth02 is offline
