2001, 2500 steering wheel vibration? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 03-16-2011, 01:39 PM Thread Starter
Whats with all this vibration I have in the steering wheel when I start and drive this 2001, 2500 Dodge Ram I`m thinking about buying? Tx, before I buy.
2001 Dodge Ram 2500, Quad cab, 6.5 Ft. Bed, 5.9L, 6 Cylinder, 24 valve Diesel, 2 Wheel Drive, 3.55 Rear, 47RE Trans, 158,000 Mi. Puke bottle mod, Stock.
triflex is offline
post #2 of 6 (permalink) Old 03-16-2011, 02:33 PM
KATOOM's Avatar
When and how its it vibrating. Could be old hard tires, tire tread, front suspension components, or power steering pump.
KATOOM is offline
post #3 of 6 (permalink) Old 03-16-2011, 05:08 PM Thread Starter
Tx for the reply, actually it only does it at idle. you put your hands on the steering wheel and you get this vibration. Once you start driving it stops right away. Maybe a motor mount? Thing is, only the steering wheel vibrates. Would a power steering pump do that?
triflex is offline
post #4 of 6 (permalink) Old 03-26-2011, 05:02 AM
K2Truck1's Avatar
Check for a 2" round steel weight glued to one of the pressure hoses coming off the pump. Dodge had a recall years ago with vibration problems in the wheel. Turns out it was a harmonic in the hoses. They glued a weight to the pressure line and it absorbed the pulses. Started in the 03 model years but I have seen it in older years as well. If the truck doesn't have it, grab a weight of about 1-2lbs, tie strap it to the hose ane see if the vibe goes away.
Livin the dream....MOST days a nightmare! 98.5TDC...Heading for 800hp summer play/race toy..1980 1/2 ton 2WD race truck...heading for low 10's with new build..1990 250,4WD,12V Shop truck...loud and proud..03 3500 quad longbox..heading for 600hp tow rig...00 1/2 ton gasser parts runner--doesn't need 1/2 hour to warm up..93 2WD Ramcharger 5.9 street killer project under construction
K2Truck1 is offline
The Following User Says Thank You to K2Truck1 For This Useful Post:
CSC 5150 (02-01-2014)
post #5 of 6 (permalink) Old 03-26-2011, 11:20 AM Thread Starter
I will check it. TX.
triflex is offline
post #6 of 6 (permalink) Old 03-26-2011, 09:41 PM
K2Truck1's Avatar
No problem. Let me know what you find.
K2Truck1 is offline
